Results 1 to 10 of 16
- 99
October 16th, 2002 03:15 PM #1Hello, I hope you remember me from kotse.com and theveed's detailing forums
My ride is a 1999 323 GLXi 4-speed A/T. While most A/T cars have the overdrive or OD switch, mine has the "Hold" switch. According to the manual, if the tranny is set to D, then the gears can only go up to the 3rd gear, if in S, the gears can only go up to the 2nd gear, and so on and so forth (BTW my tranny sequence is P-R-N-D-S-L). Question is, what is the best practice when enabling "Hold"? Kasi there are some that say to just put the gear to D and the auto tranny will do it all for you.
- 230
October 16th, 2002 04:28 PM #2the hold switch basically has the same functions as the OD switch. in most a/t cars, when the OD is turned off and gear shifting is limited only up to the 3rd, the shift point is usually at a higher rpm. this will result in faster acceleration at the drive gear and, of course, make the car less fuel efficient. just put the shifter on "D" with the OD switch turned on or the HOLD at off during normal driving.
October 17th, 2002 12:55 PM #3
During normal drivng, just keep it in D. The "hold" in the 323 is equivalent to o/d off.
When you put it in o/d off or keep her in lower gears, the engine will also tend to stay in gear or "engine brake" thus giving you more control when you need it in situations like driving on mountain roads or in slippery conditions. Engine braking the matic tranny on a steep mountain road is important for it will put less load on your brakes.
In addition, always check your ATF level to make sure it's filled for a tranny that lacks ATF will lead you to an overhaul. You have to drain and change the ATF every 40K as well.
- 99
October 19th, 2002 01:36 AM #5
I beg to differ from the opinions of the other peeps who replied before me.
The Mazda 323 A/T tranny is pretty much different from other A/T works in terms of how the "hold" operates.
In a normal A/T, the O/D just gives you that extra high gear for better fuel economy when on a highway.
In the mazda 323 familia, the "hold" doesn't operate the same way as the O/D. With the "hold" off, the tranny operates like any other A/T. But with the "hold" on, it basically turns the A/T into a sort of manual select tranny with 3 gear settings.
Example:
Setting: A/T hold is ON and shifter is in D or 3. The gas is floored.
Result: tranny will quickly shift from 1 to 2 to 3 and stay there but it will only stay in 1 & 2 gear positions just long enough to get to the MINIMUM speed to shift to the next higher gear.
Setting: A/T hold is OFF and shifter is in D or 3. The gas is floored.
Result: tranny will let the engine rev up to redline before shifting from 1 to 2 to 3 to 4. The tranny will optimize all the revs available before shifting to next gear.
This is explained in the car's manual. Better read it for more details. :idea:
- 99
October 28th, 2002 05:49 PM #6Setting: A/T hold is ON and shifter is in D or 3. The gas is floored.
October 29th, 2002 07:41 PM #7Originally Posted by gjtech
BTW, is your Familia's shift give a noticable "shift-shock" when it shifts gears or smooth siya? I am rather concerned kasi. It might require some servicing already.
- 99
October 30th, 2002 01:44 PM #8BTW, is your Familia's shift give a noticable "shift-shock" when it shifts gears or smooth siya? I am rather concerned kasi. It might require some servicing already.
I replaced my ATF recently (at 40+K) and did not notice any marked improvement in feel. Just gave me some peace of mind :D
October 30th, 2002 05:46 PM #9
I guess its normal for the Familia. It because my gf was looking to buy s 2nd hand sentra months ago and among other cars we tried, there was one sentra a/t which had a very pronounced shift-shock. It was strong enough to jerk your head backwards for half-a-sec... The guy trying to sell it said it was "normal" for that model sentra. Sheesh!!! I didn't mention I already drove 3 other sentra a/t that day and another 4 before that day!
And that guy was a sales guy from Nissan UN Ave pa!!!!
- 9
October 31st, 2002 10:38 PM #10I'm also driving a Mazda Familia A/T, in my case I feel the shift-shock during 1st to 2nd gear shifting at parang mabilis magshift. I think for a 20-25 km\hr reading sa speedometer nakapagshift na siya sa 2nd gear, tama lang ba yun? But after that noticeable shift-shock, shifting from 2nd to 3rd and 4th gear smooth na siya.
high idle RPM at engine start
