No, walang problema yang car mo. INVECS II yan di ba, so naka-OD OFF mode ka. OD stands for "OverDrive". ganyan ang INVECS II pag OD-OFF mode. pag OD-OFF hindi siya magshi-shift to overdrive and it will shift at a higher RPM. pag OD-ON naman magshi-shift siya sa overdrive pag nasa 70kph or above na takbo mo and it will also shift at a lower RPM. parang "sports mode" yan sa ibang cars, OD-OFF= sports mode, OD-ON = normal mode.
may button dyan sa may gear shift lever to switch from OD-OFF to OD-ON. saka may light dapat naka-indicate dyan sa intrument panel kung OD-OFF. pag OD-ON walang light.
