Quote Originally Posted by rey_rya View Post
........Can you please elaborate this "shift shock". If it means it jerks when you shift to D, your engine's RPM might be too high because the engine has not attain its normal operating temperature and the ECU is feeding more gas to the engine. But if the RPM is still high even at normal operating temp of the engine, you may want to adust the air fuel mixture to have the correct RPM, IMO.
ako din sir naexperience ko jerk sa shifting A/T due to high rpm, so ang ginawa linis ng MAF, choke, air filter at palit ng intake sensor.. ayos na naman...
pero pag malakas nga yung jerk as in me "thud" sound pag reverse, drive or neutral.. sure me tama na yung gear mo...
