Results 1 to 17 of 17
    Galant Super saloon 1997 A/T
    Incident: on a stop and go trapik, nabigla ko ang apak sa accelarator, na paiyak ko ang gulong sa bigla at malakas ang biglang arangkada ng kotse.
    later on, after parking for a whole day at pauwi na, i shifted to drive, walang response... antay for 1 minute...nothing happens, shifted back to neutral and back to drive...nothing happens, when i shifted back to drive, 2nd and L... wala parin
    but.. when shifting to reverse, engage agad at walang problema.
    I need to shift to drive, and then press the accelarator...umaabot ng 2000rpm bago mag engage drive...kaya laging kumadyot ang kotse.
    i test drive it.. pag nasa drive na at umaandar no problem sa shifting, lahat ng shift at nag down shift... ang accelaration wala din problem.
    na feel ko lang lagi ngayon, everytime a made a full stop from a relatively high speed where i think na nasa high gear ako ... na feel ko pag full stop pag nag downshift na sya to 1st gear, me shift shock na, dati wala.
    walang nag blink sa gear ligths walang ibang ligths or check engine din na naka ilaw.
    the ATF was changed last year including the strainer/filter. the ATF doesnt smell burnt... kulay pula pa color.
    I have it checked sa rapide, they changed again the atf, pull down the oil pan, changed the filter, then made a diagnostic test sa ecu... walang nakitang error code.
    verdict nila; nasira daw first gear, me kumalas daw at kelangan palitan ang buong transmission... a very expensive quote ang sinabi
    need your help... advice... suggestion... me naka experience na ba ng ganito sainyo
    thanks...sorry for a long explanation
    all i can say is that you'd better get a second opinion from a shop that's more reputable than rapide. there are so many horror stories w/ regards to the way they treat their clientele bro
    Aug 2004
    Ask around for surplus transmissions in Banawe. Also try browsing through Mitsu-specific forums and you might get lucky.
    Dec 2004
    Quote Originally Posted by emdee_27 View Post
    Hmmm... first order of business, get a second opinion. We generally don't trust Rapide...
    Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
    Dec 2003
    sakitin ata talaga ang late 90s a/t galants...
    Aug 2005
    nagkaproblem ako galant pag shift cya ng 2nd at minsan pati sa 3rd may kadyot sya na malakas (makakalog ka nga sa loob ng auto hehe) ng binuksan ko ung computer box ng A/T may busted na capacitor pinalitan ko same value ok na uli. may problem pa yan na hindi na nagshshift nka hi-gear kna lang prati palit box ang katapat..... nka 3 box nko wwaaaa
    visual inspection at test using vom sa sirang 2 box may busted na transistor naman ang problem
    update:
    after 2 days na hinde ko pina andar ang kotse
    now, hinde na siya umuusad, but the reverse still working.
    I think palit na nga tranny nito, nagtanong ako sa banawe 15k daw plus labour na 2.5k
    Aug 2005
    update:
    malamang palit kna nga bro pag hindi na tumakbo sign ng palit or overhaul yan eh try m ky cinco or s iba pa na importer ng surplus ng makamura ka, may frend nagplit 2yrs ago nsa 9T ang surplus
    di kaya sa linkages lang yan?
    Jul 2006
    ^^ my thoughts too. Parang biglaan masyado for ALL forward gears to just die out.
    Quote Originally Posted by afrasay View Post
    yung linkage ba nasa loob din ng tranny? pano ma check yung linkage... isip ko kasi pag sa shop e tiyak na sasabihin nila palit na tranny... yun kasi pinaka madali sa kanila....
    alam ko kung sira torque converter e pati reverse din hinde na gagana...
A/T ayaw mag engage Drive
