Results 41 to 43 of 43
- May 2011
- 481
September 18th, 2017 12:05 AM #41Hoho ngahe.
That's why I suggested to take the solenoid off the reins of the BCM. Older cars did not have this solenoid.
Yes the proper way is to check the circuits wire by wire and check the BCM. Better yet try with a known good working BCM. The TS is trying to reach out for a solution maybe because that was how much he is willing to spend on it.
I still did not get the type of car with the brake light switch on the negative side of the load.
September 18th, 2017 01:46 AM #42
salamat sa mga suggestions/instructions mga bro.
if ever, baka i permanent ko nalang yun shift lock na naka disable; unless may uber negative effect ito (aside from possible SUA).
October 22nd, 2017 07:03 AM #43
hope the car runs fine now. this is the reason why I'm in tsikot. daming gurus. daming matutunan dito.
Sent from my SM-G610Y using Tapatalk
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
