Results 1 to 20 of 33
    When I bought this 2nd hand car, it seems it was in good condition. I did checked whatever was the protocol when buying 2nd hand cars. But just recently, when I made a long trip and tried to test the car speeding up to >120kph I felt a strong slipping, meaning the speed suddently slows down while the rpm increases even when the accelerator is pressed hard. When releasing the accelerator, the rpm eventually normalized while the speed dropped down to 80kph.
    For those who are familiar with A/T, may I ask whether this is a sign of a serious problem on the A/T. Any suggestion where I can have it checked? How much would it cost me for this?
    I would appreciate if I can get a reasonable answer/suggestion on my inquiry.
    Thanks and regards,
    Bill
    sounds like the tranny is starting to "die" ...
    so how do we "revive" it?
    So tempted to say... "unDIE"
    Sep 2005
    Check m muna bro ATF mo baka overfill or kaya nmn kulang.
    Quote Originally Posted by al00399 View Post
    kung kulang ATF, won't the tranny slip when the car is first used in the morning?
    Quote Originally Posted by istan View Post
    generally:
    -check atf level... if low or overfilled, adjust to proper level
    -if the atf smells "burned", replace with fresh atf.
    -if problem still exists, you might want to consider getting a surplus tranny to replace defective tranny in your car.
    hindi kaya barado yung a/t filter?
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Feb 2006
    tama. try mo muna palitan ng atf at filter.
    if problems persists, hanap ka na lang surplus na tranny.
A/Transmission: Slipping problem at high speed
