Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Dec 2003
    With normal use and proper maintenance, what would you say is the average life expectancy of an automatic transmission?
    Would it be realistic to expect a typical 10-year old vehicle with AT to still be reliable and operate properly?
    The reason I'm asking is the tempting price of early 2000s Ford Escapes, with the 3.0 V6 XLTs in particular. They seem value for money on paper with leather seats, a sunroof, 4X4, and modern safety features for around 250K. It seems that Ford only released AT versions so I have no choice. This would be my first AT if ever I decide to push thru.
    Gas consumption aside, can I expect trouble-free ownership or will I be buying a money pit?
    With proper maintenance it should last the life of the car.
    Don't know about Fords. I did keep an AT 1995 V6 Ford Contour until 2008. The original AT still worked up to that point. I have a 2006 Sonata V6 I bought back in 2005. So, it's over 10 years old. It still accelerates to 60 mph below 7 seconds. In fact, it seems to accelerate smoother now compared to when it was still new.
    One thing I noticed with the AT is the car is harder to abuse unlike a MT which I can easily red-line and bust the engine gaskets if I'm in the mood. An AT will simply not let me do the same. That's why there is the perception AT cars have less performance than their MT counterparts. But, they're also less prone to abuse by the driver.
    I have yet to see any part replacement for the AT of my Sonata and I've been abusing it almost daily for the past 10 years.
    it's not years but the mileage. but 10 year old 3.0 v6? i'm more concerned with the FC.
    Jun 2006
    2010 was the year got my 2nd hand lovelife 99 gli a/t at 112thou km . After 13yrs, reverse started acting up, problem was it took 10min to engage the reverse from a cold start. After that no problem with the tranny.
    After 15 years problem is still here, no amount of flushing cured it and im still coping with the tranny since it only happens on cold starts.
    I got a new vios 1.5 a/t. Its indicated in the manual that under normal condition, fluid does not need to be change.
    Quote Originally Posted by shibby75 View Post
    I think it says inspect at 40k or 50k? Toyota replaces that for severe-condition countries like pinas.
    BTT
    for properly maintained trannies 300k is doable.
    Jan 2009
    Buying 10+ year-old A/T cars is "like a box of chocolates", to borrow a popular phrase. It is somewhat difficult to determine how the vehicle was driven or taken cared of, much less, ascertain the condition of the A/T. I guess you can do a few things:
    1. Check service records
    2. Check the fluid quality (but which is never conclusive)
    3. Check for evidence of leaks
    4. Test drive
    Most issues not apparent during inspection will likely come out during the test drive. Try to feel the shift quality. Under normal driving, it shouldn't give you shift hesitation, delays or slippage, regardless of engine temp. Work through all the A/T shift positions and modes (if equipped) like O/D off/on, ECT, engine braking, etc. and make certain that they're all working.
    Research beforehand all the features of the car you're trying to purchase.
    V6 nga pala...forget it hahaha.
    Jun 2006
    Eto nakasulat sa dipstick ng vios, no need to change under normal driving condition.
    you don't want to skip atf changes. is this your first car?
    Without regular ATF changes, your AT will really suffer premature death.
    Experienced it with my Mazda 3 as the previous owner never seemed to change the ATF. Replaced the AT and placed the proper spec of ATF (MV, not Mercon V or Dexron III). Now the AT runs smoothly and shifts very quickly.
    Even if its there, just change ATF at 40k kms.
    Its for the good of your car and your pocket. :D
    Jun 2006
    No its not my 1st car. Its my first bnew Automatic car,mileage is at 12k still a long way to go for the 40k mark.. Got fed up with manila traffic.
    When i got my 2nd hand lovelife at 110k mileage, atf looks and smells burned. previous owner might not had any idea that it needed to be changed periodically. Changed ATF with orig aisin fluid, after a year or 2 of use reverse started acting up.
    thanks for this info kasi madami ng kumukuha ng AT ngayon. ako nga masgusto ko mag drive ng AT kasi hirp traffic
    Mar 2015
    170k+ km na ang 1st gen crv ko at wala pa ako naging problema sa trany nya.lakas parin umarangkada.alaga lang yan lalo na pag may leak check mo regularly ang level sa dipstick.at amuyin mo kung amoy sunog,masama na yan
    Mar 2015
    Kaya nung naglabas ako ng monty nung last May, AT parin pinili ko para mas maginhawa para kay misis
    maslalo na parating ang pasko sobra as in sobra sobra na naman ang traffic!
    sana maayos na nila ang mrt/lrt para may option!
    magdala o magbaon ng madaming madaming pasencia
    Apr 2010
    Manila driving is considered in the 'extreme' side - heavy traffic, long idle time, pollution, etc etc. Kung hindi naman kamahalan yung AT fluid (Dexron III mineral oils are around 200/ltr) kahit every 20k palitan mo na.
    I do ATF changes now at 10-15k, around 1.5k oil and labor. Crisp shifts and laging amoy bago ang trans fluid
    Every 40k km pala ang palit ng atf. Sa owners manual ng 2012 kia carnival ko sa normal usage condition no need to replace atf. sa severe driving condition naman every 100k km ang palit
    Jul 2011
    Question guys.
    Can I start up the engine after I drain the fluid to pump the remaining fluid in the torque converter.
    Because I read an artcle that 50% of the fluid remains in the torque converter?
    TIA
AT Tranny Life Expectancy
