Results 1 to 4 of 4
    Mar 2007
    bumili ako repair kit for secondary cylinder to have it changed.after mapalitan tumigas clutch tpos may ingay cia pagapakan.squeaking sound.sabi ng nagpalit may kelangan lang daw lagyan ng grasa.nakalimutan ko kung nung exact part ung grasahan.normal lang ba na tumigas ung clutch at magkaingay after mapalitan?iba ung feel nya compared before cia palitan.
    Quote Originally Posted by dcarlo187 View Post
    Dapat hindi sir. Kaya nga pinaayos mo yan para almost back to normal. Plus the sound is disconcerting considering na dati wala niyan. Ipa-back-job mo agad sir. Sabihin mo na hind naman ganyan dati. La ka kamo peace of mind.
    Na-check mo ba sir if yung repair kit is ideal for your car? na-check mo ba na yung pinalitan at yung repair kit ay same yung dimension/size/appearance?
    Mar 2007
    sabi naman ng friend ko bago pa daw kaya mejo matigas.pagnababad na sa break fluid edyo lalambot na.o kaya baka kelangan p ibleed.same size naman ng part.sa auto supply ko nabili.ung sa ingay naman ung plunger daw ata kelangan grasahan.pero pacheck ko din sa iba.
    May 2009
    mukhang nagalaw ng siraniko este mekaniko mo yung orientation ng release bearing-fork assembly ah.....squeaking sound high pitched? usually moving part yan not in the hydraulic circuit.....
squeaking sound
