Results 1 to 9 of 9
    Nov 2006
    Quote Originally Posted by talohunter View Post
    I drive a 96 civic vti. Every time I release the clutch pedal it squeaks. It started about 2 months ago but the sound wasn't audible yet and it wasn't all the time. I can just "feel" it. Now it squeaks all the time. Can this problem be serious? Speedyfix is far from our place so I'm planning to have the clutch checked on my next pms which is 2000km away. Or would you recommend I have it checked as soon as possible?
    depende sa squake kung andyan ba sya sa tuwing inaapakan mo yung clutch pedal kahit engine off or naririnig mo sya sa tuwing inaapakan mo ang clutch pedal na umaandar yung makina.
    kung engine off,possible binding metal lang yan between pedal arm and clutch pedal bracket or cable.lubrication lang kailangan.
    kung engine running. possible throw out bearing (release bearing) damage.kailangan palitan.
    Jul 2006
    Di pa naman siguro ung knees ko yun. Bata pa naman ako at nag ggyym. The squeaking sound is still there even though the engine is off.
    as what dennis said, it might be just binding metal...or the spring.
    May 2007
    not sure kung tama yung name ng pyeza, pacheck mo yung sa may clutch assembly (yung me pressure plate) baka kailangan na palitan yung clutch bearing.
squeaking clutch pedal
