Results 1 to 20 of 26
    ganon po ba sir AY? pero more of squeaking lang naman... sana nga hindi na release bearing, mga 4 na oras para lang baba yung tranny.
    sige sir XTO, babalik ko para matignan. baka lang wala na warranty, alam ko kasi 6 months lang warranty... sa tingin ko tapos na warranty.
    salamat po sa mga reply
    naku, clutch driver ata si archieboy after more than 6 mos umingay na ulit hehe dibale di naman grabe yan, nakaka irita nga lang. by next year or kung kelan ka libre pa buksan mo nalang ulit ganun talaga.
    btw kaya ko nabanggit na kung napalitan nga ng bago or defective ang release bearing is marami ko kakilalang mechanic na pag suot sa ilalim during clutch disk, pressure plate and release bearing replacement e sa bulsa nilalagay yung bagong bearing at me dalang luma... well di naman siguro nangyari sa yo yun.
    Oct 2008
    sir may rubber boot dun sa clutch fork nyo try mo lagyan ng wd40 basta dun lng sa clutch fork ha
    Oct 2008
    sir may rubber boot dun sa clutch fork nyo try mo lagyan ng wd40 basta dun lng sa clutch fork ha tangalin mo po ung rubber boot kasi dati naka experience me ng ganyan.. brake cleaner pa nga nilagay ko.. aun po sir
    sir XTO, hindi po clutch driver, power shifter lang :bwahaha:
    oo sir nakakairita talaga. parang may mickey mouse na naiipit bawat apak sa clutch.
    technismo... sige sir subukan ko yan bukas para mawala na yung ingay. kakairita talaga eh.
    maraming salamat sanyo lahat
    Nov 2003
    have the fork greased. if di mawala then kelangan ibaba yung tranny ulit.
    Sep 2008
    I would like to ask the experts here if it is OK to use a single cap piston for the clutch slave cylinder even if the OEM piston has double caps? .... I'm having a hard time looking for a double cap repair kit ..... Looked also for a brand new assembly but I cannot find one... Thanks in advance!
    sometimes squeaking is simply pedal adjustment specially if the pedal is too high... that happened to me once
    Apr 2009
    mga sir alam ko po mejo po matagal na tong thread na ito pero gusto ko lang po itanong kung papaano po napawala yung squeek currently po ganun rin po yung akin ampanget ng tunog kakairita umingay lang siya nung lumamig yung panahon tapos tumigas rin ng onte. clutch cable lang po kaya yung akin o me mga iba pa, kung clutch cable pwede po lagyan nalang ng wd40 oh grease? sa loob po galing squeek at parang ampanget kasi ginagawa kong maganda ride comfort ng mga sumasakay sakotse ko sabay squueeekkk ingay ng clutch
squeaking clutch
