Originally Posted by Ungas
nice input, di ko din alam kasi yan, thanks Ungas.
help peeps.
i hear a "grinding" noise when my car is idle, but it dissapears when i depress the clutch.
whatcha think peeps??:P
benchph1::: Baka naman po clattering sound ng clutch release bearing yung tinutukoy nyo? The grinding noise should only be heard when a gear is engaged and the vehicle is in motion, may sira na ang trannys. Pero kung grinding noise during idle and lessens when the cltuch is pressed, only one thing comes into my mind, clutch release bearing is not properly mounted.
yup yup tumpak sir ungas....i can only hear it when idle and the noise dissapears/lessens when i depress the clutch pedal. my car is already 6 years old,
although the clutch is not yet sliding, palitan ko na ba clutch disc?
benchph1::: Tolerable naman yung clattering sound ng clutch bearings, pag di pa nagbibigay ng senyas na sliding clutch pwede mo pa pag tyagaan para hindi sayang ang labor. :D
hmmm think youre right....sayang nga din ibabayad ko sa labor..wala lang sobra ko lang kasi baby ang kotse ko, hehehe kulang na lang isama ko sa pagtulog. nway thanks a lot sir ungas
benchph1::: No problemo sir! :D You could also try stepping on your clutch again and slowly releasing it para mawala yung ingay. This is sometimes effective.
pag tumataas ung rpm mo pero parang di bumibilis yung oto, sliding clutch ba yun?
kiro::: Yes, it is a possibility. Yung sasakyan nyo po ba ay may tachometer? Kahit wala nun, mararamdaman nyo naman pag shift nyo ng 4th gear di agad humahatak ang power ng makina. Or even down shifting to 3rd gear, it will take a couple of seconds before you could sense the power of your engine. :D
thanks ungas.
ganun nga...tapak ka sa gas, angat rpm, pero bagal oto hehehe.
kiro::: Your welcome. :D Pwede pa yan gamitin for a couple more kilometers. Pag hirap na ang power from 2nd to 3rd gear, palitin na talaga yan.
ungas,
pinalitan ko na.
kakaasar eh bagal bagal.
tunog ng muffler mo eh 120, andar mo 20...:lol::lol::lol:
update ko lang....
hindi ko pa napaayos clutch ko as of this time, pero naalala ko, before nangyari yung sliding ng clutch ko, tumigas muna yung clutch pedal ko......
and sometimes, nangyayari ulit ito but there was no sliding sa clutch. Bigla na lang tumitigas yung clutch pedal then after some time, babalik sa dati. Is this still part of the problem?
phillipogi::: Ser, baka po nasa master clutch nyo ang diperensya. Kung wala namang master ang clutch, nasa vaccum na papasok sa clutch. Malamang may bara ang hose kaya tumitigas or may singaw ang hangin sa assist ng clutch kaya tumitigas.
