Results 1 to 2 of 2
    Feb 2009
    Hi All,
    Recently I noticed that the gear shifting of my ride (Corolla SE 1995 1.6 Gas) is a bit rough on 1st and 3rd gear while running, parang may sumasabit. Other gears are fine. I had checked the clutch play and it is fine.
    Can you what are possible causes of this? I planning to have it check with a mechanic this weekend but I need some opinion first. Newbie pa kasi.
    Thanks.
    try setting the idle rpm lower.
Shifting Problem
