Results 1 to 8 of 8
- Jul 2011
- 1,711
May 8th, 2012 02:33 PM #1Mga Sir, ask lang po ako ng help
Me problem po ung shift gear ng RAV4 (2nd GEN).
Pagtapak ko ng brakes (medyo matigas), at pinindot ko ung botton sa may (parang clutch) matigas din at ayaw pumasok.
Para mailipat ko ung shifter, pinidot ko ung SHIFT LOCK then tinapakan ko ung BRAKES, saka ko lang nailagay sa reverse.
From D-R-2-L ok naman at hindi resistive ang brakes, pero once nilagay ko na sa P, balik ulit ako sa mahirap tumapak sa brakes at ayaw pumasok ung button sa may ibabaw ng shifter.
Check ko po agad ung mga brake fluid, transmission fuid, engine oil, pero asa tamang level naman po.
Ano po kaya ang mga possible reason at nag lock sa P ung shifter.
- Jun 2005
- 3,774
May 8th, 2012 11:18 PM #2check your brake lights or fuse connected to d brake lights... happened to me last saturday on a city.
turns out, i can only shift from park if the brakes are fully depressed. without the brake lights, there was bo signal to the transmission that the brakes are depressed.
changed a busted fuse, ok na ulit
- Jul 2011
- 1,711
May 8th, 2012 11:48 PM #3yes sir check ko ulit nde nga nag work ang brakelights ko, nag search ako sa fusebox under the hood buo naman, so duon naman ako sa fuse malapit sa ibaba ng steering wheel meron ako nakitang busted fuse 7.5amp
napalitan ko na ung fuse na un at working na ung mga brakelights ko, pero ung problem ko sa shift gear ganun pa din.
ung fuse ba na pinalitan mo same location tayo at 7.5amps din? baka kasi meron pang ibang fuse na busted na nde ko nakita
- Jul 2011
- 1,711
May 9th, 2012 07:45 AM #4Sir ok na po ung shifter, found another busted fuse 10amps, dun din sa fusebox malapit sa steering wheel.
In summary, ang affected na fuse
7.5amps for brakelights
10amps not sure kung para saan
mamaya idaan ko sha sa suki kong talyer para i plug sa diagnostic tool at malaman ko kung resolve na ba ung shifter problem ko.
thanks po sa info about busted fuse at brakelights, and ung relation nito sa shifter.
May 9th, 2012 09:47 AM #5
pag busted ang fuse sa brake lights, affected ang pag shifting ng AT? delikado pala.
- Jul 2011
- 1,711
May 9th, 2012 10:35 AM #6Yes sir parng safety feature ng RAV4 since delikado nga naman sa kasunod mo kung nde nya makikita na nag step ka ng brakes, mababanga ka sa likod.
Kagagaling ko lang sa mechanic, so far ala naman sha nakitang ibang problem, at ung shifter ko ok na.
- Jun 2005
- 3,774
May 10th, 2012 01:00 AM #8good to know nakatulong post ko! Hehe
bettet check mo na din yung cause ng busted fuse mo pati kung anong electrical system ang affected. yung sakin kasi, naglagay ako ng bagong busina tapos nagkamali ako wiring ng relay. 10amp ang fuse na pumutok, connected sa brake light and horn.
