Results 1 to 4 of 4
July 29th, 2013 08:06 PM #1
Mga master tanong ko lang po, yung shift stick po kasi ng kia pride ko masyado malaki yung play,
I mean if galing sa neutral pag shift sa primera ang laki ng tinatravel ng shift stick para pumasok and hindi din sya bumabalik sa gitna pag naka neutral.. may problem na kaya sa transmission to?
thanks po...
Kia Pride GTX po...
July 29th, 2013 08:45 PM #2
I am not really familiar with the Kia, but it may be due to worn down shift lever bushings or shift cables out of adjustment / slack / loose. Sa Benz kasi, shift lever bushings lang pinapalitan ko, nice and tight na ulit.
August 1st, 2013 11:22 AM #4
update:
wala ko mabili mga bushing so buong shifting assembly ang pinalitan ko, but the problem is still there
high idle RPM at engine start
