Results 1 to 10 of 17
- Nov 2004
- 45
September 22nd, 2011 03:03 PM #1Fellow forumers pa help naman
I've been driving an Altis 2006 Automatic 1.6
Coming from a cold start , I can start the engine easily and do the reverse without delay.
When I shift the gear to "D" Drive, it won't respond agad, I need to gas up up to >10 seconds (making a whining sound)
Then I can move forward.
After this ok naman po ang ride.
Pa recommend naman kung ano dapat
Thanks
September 22nd, 2011 03:08 PM #2
Have you checked if the automatic transmission fluid level is correct or low?
Also, how you normally park at home? On level ground or on a inclined ramp or street?
- Nov 2004
- 45
September 22nd, 2011 03:33 PM #3At home i park at almost level ground (kinda sloping down little bit) (at home if neutral it will go forward very very slow)
- Nov 2004
- 45
- Nov 2004
- 45
- Jan 2008
- 4,726
September 23rd, 2011 09:31 AM #6dapat walang delay.. how about the ATF fluid?? tama ba specs nung fluid na nilagay mo?? kasi during cold start medyo malapot pa yung fluid.. baka may dumi or bara sa mga oil galleries nung transmission.. baka need mo din papalitan yung ATF filter kung meron man
- Sep 2016
- 98
November 20th, 2017 09:33 PM #7
November 21st, 2017 02:31 AM #8
you should have changed the atf at 20k 40k 60k 80k 100k 120k 140k..
how many did you miss?
November 21st, 2017 02:42 AM #9
November 21st, 2017 02:45 AM #10
mali ang tanong ko dapat 40k 80k 120k 😅
While being a bit of a looker, it's not useful enough for other purposes outside of point a to...
VinFast VF 3
