Results 1 to 15 of 15
    curious lang ako... pano nga ba? enlighten me pls, tnx
    Place in "P" position?
    Alam ko by stepping hard on the gas pedal, auto tranny shifts down a gear. Then without releasing pressure from it, shifting patterns change to sport type simultaneously reaching just above the red line limit.
    tama, step hard on the accelerator pedal will downshift. pwede mo din gamitin yung shifter. from D lagay, off mo yung overdrive, tapos lagay mo sa 2.
    Signature
    with overdrive OFF, shift from D to 2 or L depending on your current speed.
    Mar 2003
    yud, they r all correct. just step on d accel hard 2 achieve kickdown
    on downshifting, i press the hold/over drive button...pero may max speed lang kung gagamitin mo yun..sa manual ng mazda nasa 70km/h
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    the Mazda 323 Familia A/T is different from the automatic transmissions found in Toyota & Honda cars.
    ganun ba? didnt know that...diba same thing lang yung hold and over drive? alam ko sentra has this..pati rolla (big body), civic alam ko wala (vtec3, not sure sa older models)..paenlighten naman sir..pati what makes it different
    Toyota Corolla GLi A/T
    When in D w/ OD on: the tranny shifts thru gears 1,2,3,4
    When in D w/ OD off: the tranny shift thru gears 1,2,3
    when in 2 w/ OD off: the tranny shifts thru gears 1,2
    when in L w/ OD off: the tranny shifts stays in 1
    gear use with OD/off is the same as with OD/on except with the use of the 4th gear.
    When in D w/ hold off: the tranny shifts thru 1,2,3,4
    when in D w/ hold on: the tranny stays in 3, using 1,2 only minimally
    when in 2 w/ hold on: the tranny stays in 2 using 1 only minimally
    when in 1 w/ hold on: the tranny stays in 1
    in Mazda 323 Familia with hold "on", the tranny will only use the other gears long enough to reach the minimum speed to use the user selected gear as compared to with hold "off" it will use all the gears to reach optimum speeds in each gear.
    Magkaibang-magkaiba ang HOLD at O/D.
    learn something new every day salamas!
    the mazda 323 familia a/t tranny is fun to abuse especially if your shifter-lever doesn't stick (smooth shifting). Plus the engine is very torquey and more than willing to rev up all the way to the redline. Front-rear weight is good and with enough speed and proper technique, drifting the familia is fun although recovery from a drift isn't as smooth as I would like it to be.
    yup!tama ka dun sir ghosthunter!! :cool: minsan ngamasyadong abused si mazda ko e! :freak:
    so Caloysky5, what have you been doing with your 323? Any adventures & misadventures you can tell us?
    lets just say na lang na high-rev driving using HOLD si caloyski during the past few weeks :D parang feeling ko sobrang na-e-enjoy ko si mazda ko
Downshifting with an A/T?
