Results 1 to 10 of 17
Threaded View
February 27th, 2024 08:38 PM #4
If wikipedia and protegefaq site is accurate then it is likely the 4AT transmission for the 1.6 has the same ratios but a shorter final drive(they made a variation with different ratios but it is purportedly paired with the 1.5 engine or found in 2014+ vehicles). There is also the possibility that mazda PH used the same 4AT transmission(or atleast final drive ratio) for both 1.6/2.0 vehicles.
ProtegeŠ FAQ - Transmission Info
[FN4A-EL] 4AT Ratios
1st gear
2.816:1
2nd gear
1.497:1
1.553:1 (*1.5 specific)
3rd gear
1.000:1
4th gear
0.725:1
0.695:1(*1.5 specific)
Reverse
2.648:1
Final drive
3.683:1
3.904:1
4.147:1
4.416:1
4AT Final Drive Ratios for the 1.6(ZM-xE/Z6-xE)
4.147:1
4.416:1
3.904:1
4AT Final Drive Ratios for the 2.0(LF-xE)
4.147:1
3.683:1
[FS5A-EL] 5AT Ratios
1st gear 3.620:1
2nd gear 1.925:1
3rd gear 1.285:1
4th gear 0.933:1
5th gear 0.692:1
Reverse 3.405:1
Final Drive
3.863:1
3.458:1
3.652:1 (*2.5 specific)
5AT Final Drive Ratios for the 2.0(LF-xE)
3.863:1
3.458:1
