Results 1 to 14 of 14
    Jun 2007
    Problem with my brother's civic lxi 96 A/T , the scenario is this nag chance na po ng atf fluid (total atf dexron 111) mga 3 1/2 liters ang naubos the problem po is ok ang hatak or arangkada sa D4 pero pag arangkada na and running na to 40 to 60 kph. ung rpm nya abot til 4-5, and di agad nag shift automatically matagal responce or me delay but after revolution hahatak na and deretso na takbo, anu po kaya problem?? ok naman ang hatak pag 1st.. me nag sabi there were a problem in computer box wala daw sa timing is that coreck po ba?? kindly help po tnx...ano po kaya better na gawin?? god bless to all..
    Jun 2007
    ganyan din prob ko with my 2001 crv. sabi sa servo(?) kit daw
    Aug 2005
    Quote Originally Posted by h2o_ym View Post
    nag change ka din ba ng ATF Filter (dont know if meron ang civic). if not pa change mo muna, saka make sure correct ang ATF na nilagay mo for your car. first step if there are auto tranny issues: Change AT Fluid and Filter.
    May 2007
    I said no on computer box......
    You have problem with upshift delayed and seems like you have a broken 1-2 shift accumulator spring or you have excessive main line pressure. Check also your driveshaft (CV axle) from the tranny, try to wiggle your driveshaft and look for loosness. If it does, have your mechanic fix that problem. By the way, did you change your tranny filter and did you distribute your fluid right into all gear after changing fluid? Numerous things may cause this sort of problem.
    Jun 2007
    gud pm mga sir..
    san po ba nakakabit ung trans filter?? i have no knowlegde po kc bout matic, kc dko napalitan filter ung atf lang po tama po ba ung nakabit ko na atf? its total dexron 111, mga 3.5 liters ang nakabit, start q kanina and sa P shift ko cya sa D4 ok naman me cpa then umabante car, then repeat ko cya in R ganun din, is that mean na ok pa ang lining ng transy?? na check ko un cv joints ok naman, i also smel the fluid and smell sour naman and redish pa ung atf,by d way nag change kme last tuesday ng atf, natakbo q na rin car,ang problem ung delay after 40 to 50kph, ung rpm goes 4K to 5k rpm, thanks po sa lahat sa inyo very big help po kau.. god bless..
    sir, anong gear ang delayed pumasok? is that the 3rd gear or the overdrive?
    Apr 2006
    bro. ganyan din ang experience ko before tulad na tulad sayo.
    nag-bakasakali lang talaga ako na makukuha sa ATF. kaya naka 3 palit akong ATF sa isang buwan. pero ganun pa rin ang nangyari.
    delayed talaga. Hanggang sa dumating yung point na nanginginig na siya and worst di na tumakbo.
    during cold start lang siya tumatakbo. abante at atrad alang problema. pero kapag uminit init na mga 15 minutes drive. dun na siya pumapalya.
    problem is the filter or the strainer. o maybe the torque converter is sunog na.
    but no choice me. kasi either way is kelangan buksan ang transmission which is overhaul nga. eh wala akong budget kaya bumili me ng surplus.
    ok naman yung surplus ko until mga 3 months na...parang lumalakas yung shift shock ko.
    ibig sabihin palpak din yung nabili kong surplus.
    gud pm mga sir..
    Jun 2007
    Sir MCBAIN...
    Thank you so much po, and sa 3rd gear nga ung delay kc ok naman ang hatak gang 2nd, kaya pag takbo nasa 40 to 50kph palang dapat diba move na cya to 3rd and going to 4rth, ano kaya problem?? Thanks po ule, more power...
    Sir Kabuke0,
    thanks din po, nagpalit na ko ng atf, pina drain ko muna then change kami ng total dexron 111 tama po ba nakabit namin o mas ok ung higher brand na sana?? ang problem dko napalitan ng filter (1st time palang kc sa Matic) where ba located ang filter banda para ma check ko? or kung magpalit aq nun palitan q ba ule ng atf?? sa gasoline station kaya ba nila magpalit?? ano brand ang maganda mabili na atf and tranny filter? Sorry nga pala to know what happen sa na palit mo na tranny..hehehe, baka pwede pa ibalik yan?? God Bless and always have the safest ride with you all..
    Sir MCBAIN...
    ganyan din un mazda namin dati....pag di bumaba ng 800 rpm at pinatakbo agad di nag-sshift ....kaya ngaun pag-start hintay muna ako bumaba 800 un rpm o kaya wait muna ako 2-5 minutes.... di ko pa pinatingnan wala budget !
    Jun 2007
    sir incus..
    thanks po, un nga din concern ko eh! ung budget,hehehe, kaya ask muna ko sa mga gurus or me alam para lam ko gawin kc pag sa mekaniko agad baka lahat papalitan..hehehe, ok naman ang rpm ng car at 1st start lagpas cya ng 1K rpm then after 3 to 5mins baba na to 800rpm, pag nag shift aq sa D4 me kick naman and sa R din, kahit d tapakan ung accelerator natakbo cya, ung delay lang sa high gear ang problem.. thanks po ule...
    Apr 2006
    sir incus..
    wag mo ng pabayaan yan bro. baka matulad ka sa akin. hehehe
    umabot din me mga 17,000 pesos lahat lahat na yun.
    Jun 2007
    sir kabuke0, naku wala pa naman ako ganun kalaki pera, hehehe, tanya mo bro ung filter or strainer mga magkano?san banda nakakabit filter ng civic lxi? thank you bro..
    May 2007
    gud pm mga sir..
    Tranny filter is inside your tranny gear box w/ bunch of lug nuts like your engine oil pan. Look under your tranny and you will see it. To access the filter you must drain your tranny oil into a clean bucket if you want to re- use your oil then remove all the bolts to drop the pan. Filter is above the pan and its a plat w/ two bolts on each side, remove the filter and replace w/ new filter. Replace also your tranny pan gasket just to play safe. Do not over tighten your tranny bolts or leak will occur.
    Tranny fluid is need an extreme attention. First put two quarts(1892 ml) into your tranny....Start you engine(idle) then shift your gear to reverse, wait for 5 seconds then shift to drive wait for 5 seconds then shift to #3 #2 #1 on each gear w/ every five seconds each. Reverse the procedure again 5 seconds each, then shift to Park stop engine check your tranny oil for level. Add oil if nessesary again do the same procedures. By doing this is, to fill your tranny gear reservoir on each gear by distributing evenly. Do not overfill or you will damage your tranny.
    Jun 2007
    Sir v6dreamer,
    thank you sir i'll do what u said, big help po kau.. sabihin ko senyo what will happen, tomorow ko cya gawin its raining kc badtrip, kahapon gamit ko cya going to mandaluyong ang gnagawa ko sa D4 pag nasa 40kph to 50kph na then mag delay ang gawin ko accelerate up to 5000rpm then release up to 3000rpm then accelerate again ako then ok na takbo nya khit mag 90 to 100kph pa, till mag menor ako back ule sa same procedure.while on idle normal ang idling nya to 800rpm.. thank u again sir and have a safety trip always..
problem with A/T pls. help
