Results 1 to 11 of 11
    Jan 1970
    my friends car(an ae92) ran out of clutch fluid(dunno how it leaked out) and hindi niya na-notice kaya ginamit pa yung kotse. nung makabalik lang siya sa bahay na-notice yung tulo ng fluid sa garage. btw, nung nagdagdag daw uli ng fluid, umitim yung clutch fluid.
    kailangan ba niyang i-flush yung clutch fluid? ano kaya effect nung ginamit yung kotse nang ubos yung clutch fluid?
    Naubusan ako ng fluid on my way to Bulacan. Nagleak yung slave sa ibaba so total loss of fluid.
    Siyempre dahil walang fluid, hindi nagdi-disengage yung clutch. I had to rev match to be able to shift and kapag stop, I started the car in first gear na.
    I didn't have the fluid flushed afterwards. I just had the system bled. Medyo naupod ata yung clutch after that episode of driving.Naubusan ako ng fluid on my way to Bulacan. Nagleak yung slave sa ibaba so total loss of fluid.
    Mar 2003
    pasinget ha?!
    saan ba banda or rather how to refill clutch fluid?!
    madali lang ba pag DIY?!
    para lang bang naglalagay ng brake fluid yon?!!
    this is one thins kasi na hindi ko pa nache-check sa car ko.... clutch system.
    peace po tayo mga kapatid :mrgreen:
    8)pasinget ha?!
    8)
    Quote Originally Posted by JAZ333
    pasinget ha?!
    Dali lang yun sir.
    Sa tabi nung lalagyan ng brake fluid is another lalagyan. If you're facing the car, sa right yun. pag salin mo nung fluid dapat hanggang dun lang sa maximum level kasi masama pag sobra, I think overflow un. Be sure that you only use the right fluid. :wink:
    I had an experience once. Sama pa nga kasi sa express! :? Better check the level first bago kayo alis and the brake fluid level na din. Nandyan nakasalalay buhay natin. :wink:
    Mar 2003
    Quote Originally Posted by krudo_bagito
    pasinget ha?!
    Dali lang yun sir.
    Sir thank you ha?!
    check mamya ........ salamat ulit!!!
    8)
    sa MB.. pag nawalan ng clutch fluid.. wala ka ng clutch.. wala ka na ring brakes.. ehehe. iisa lang kasi reservoir nya eh..ehehe
    Pag naubusan ng clutch fluid di maipapasok ang kambyo ng sasakyan. Lusot ang clutch, pag tinapakan ito masyadong malambot ang clutch pedal. Kadalasan yung slave sa ilalim ang nasisira. I think prone ang AE92 sa mga ganito. Madali lang naman palitan ng repair kit. Hinatak ko na dati yung sasakyan ng pinsan ko same model din. Yan din ang sira.
    Jan 1970
    no clutch fluid....no clutch....no drive:D
    Nangyari naman sa van ko toyota hi-ace,me fluid ako pero lusot ang clutch.try ko i-adjust yong clutch then OK na.Itinaas ko ang clutch then drive for 10 KM,then napansin ko tumutukod na ang clutch as in parang nagkahangin kaya ibinalik ko sa dating adjustment and till now it remain OK.Ano kaya problema non?
    Aug 2003
    ditto.
    no fluid = no clutch = can't change gears, quite traumatic when it happened to me.
    on some cars the brake and clutch have the same reservoir.
    Quote Originally Posted by orly_andico
    ditto.
    yup, agree,.. parang sa liteace namen,.. I'm looking also for the clutch's reservoir, wala pala, magkasama na pla sa brake yun, hehe!
possible effect sa kotse pag naubusan nang clutch fluid
