Results 1 to 16 of 16
    Mga bossing patulong naman newbie lang. Nagpark kasi ako sa basement ng isang building sa Commonwealth near St. Peter's Church yesterday nung palabas na ko sobrang taas ng paahon. At first hindi nakaya ng oto ko ang paahon so i tried to shift it sa low gear (L) pero ayaw pumasok galit na galit ang makina at kumakamot ang gulong. So what i did was umatras pabalik sa basement para kumuha ng bwelo and i activated the overdrive. Finally nakaahon ako. My worry is after this may naamoy ako na parang sunog na goma. Is it the ATF or nagoverheat and tranny ko or gulong lang yun na naginit sa sobrang kamot? Paadvise naman hindi kasi ako mapakali baka nasira ang tranny ko. TIA.
    May 2007
    Its just a burn rubber. Dont worry your tranny is very much okey. Anyway, go easy on uphill unless your engine is a brawler.
    Quote Originally Posted by v6dreamer View Post
    Thanks v6dreamer. My other concern is that it does not shift to low gear which is "L" right? is there something wrong with my tranny or it is just the stick shift? Thanks again.
    Aug 2004
    You can test this by putting your tranny in L and driving around. If your tranny still shifts to a higher gear as you speed up then you might have a problem. If your tranny stays in one gear then no worries.
    Were you shifting while you were stepping on the gas very hard? It might be your tranny saving you since if you are revving the engine very high as you spin the tires and shift to a lower gear you are more likely to cause tranny damage. The last thing you should be doing going up a steep incline is using overdrive as that allows the engine to go to the highest gear. Going up steep slippery inclines it is better to be light on the gas to prevent wheel slip.
    Quote Originally Posted by redorange View Post
    No i was not shifting while stepping on the gas. I was on a full stop when i tried to shift it to "L" but in vain. Thanks.
AT Not shifting to low gear
