Results 1 to 6 of 6
- Feb 2013
- 1
March 22nd, 2013 06:58 PM #1Hello. I drive a Mitsubishi Spacegear (gas, 2003) and I have been having problem with its overdrive. When OD is on, I hear a loud clicking sound behind the glove box. No pattern at all, it's very random. Sometimes it's not there, sometimes the clicks are in short bursts, sometimes far and few in between and there are times that the clicks will be rapid and non-stop, to the point that the car will be confused and will keep on shifting gears. When this happens, I just turn the overdrive off.
Has anyone had the same problem with overdrive? May I ask for some advice/recommendations? Thanks in advance!
March 23rd, 2013 09:27 PM #2
March 26th, 2013 12:41 PM #3
any idea how to bypass these three or some mcguyver for a "manual" overdrive....i've looking for a way on how to engage the overdrive with just the switch, etc....my pickup truck which has been converted (formerly a gasser) to diesel by the previous owner cut all the wiring connections to the computer with no trace of the previous connections. it's a PITA. 4d56 diesel aisin AW 0372L trans.
March 26th, 2013 07:50 PM #4
provide power to the light blue wire to the solenoid through a relay
check the wiring diagram on 4-64 http://delica.107net.ru/L400/ELECTRI...cal_wiring.pdf
March 27th, 2013 10:21 PM #6
can't identify the exact location of the OD solenoid. the trans cooler lines are on the right side (with respect to the driver's seat) and the wirings just snakes its way below the driver's.
if ever, would this be a good alternative? Overdrive quit
thanks again
BYD Sealion 5 DM-i: BYD’s powerfully efficient subcompact crossover now in PH | Top Gear...
BYD Sealion 05 DM-i
