Results 1 to 12 of 12
    Apr 2011
    mga sir, may piyesa po ba niyan? kasi sabi nung mekaniko winelding lang nung dating owner yun parang connector sa transmission. as you can see parang hindi na siya direcho may welding na sa gitna. sabi niya kelangan daw palitan yun buong transmission although ok pa naman siya kahit ganyan. 10k daw kasi, kaya hanap ako ibang alternative para dyan.
    zoom-in picture:
    ImageShack® - Online Photo and Video Hosting
    Feb 2009
    Quote Originally Posted by sn0wbLind View Post
    zoom-in picture:
    from what it looks like, it might be a nissan sentra manual transmission. yes you can buy this part separate. it is the shifter shaft
    Jan 2009
    Yepp. Definitely looks like a Sentra. From the looks of it, I think the previous owner or mechanic extended the lever, maybe to make the clutch softer. However, doing so definitely changed the clutch geometry.
    It is very common in the Philippines for mechanics to try and work around the problem rather than solve it.
    Apr 2011
    yes, its a sentra! pwede pala yan lang ang bilhin na piyesa. sa banawe kaya meron niyan? pansin ko nga sir, ang hirap timplahin nun hindi pa ko sanay, mabilis mamatay.
    kung ok naman pagkakaweld, bakit need mo pa palitan?
    no need unless sobrang haba nang idinugtong...you can adjust naman the cable at your acceptable preference...
    kung namamatay naman, baka sobra lang baba ng idling...
    BTW sakit ng sentra ang matigas na clutch. usual cause ay yung cable, then yung bearing and pressure plate....
    Apr 2011
    thanks sa input sir. siguro dun na lang ako mag iinvest sa clutch repair kit. usually 4.5k daw eh. may naririnig kasi ako parang bakal na nag uumpugan pag nag chachange ng gear pero minimal lang yun tunog nya. normal po ba yun?
Transmission problem
