Results 1 to 8 of 8
- Nov 2009
- 2
November 2nd, 2009 02:15 PM #1guys help naman po, yung tranmission ayaw pumasok sa third gear pag umaandar pero pag nasa lifter sya eh pumapasok naman yung third gear. we already replaced the trasmission with a new one. we did seek help from japan subaru pero di nila kami sinasagot. baka may pwede pong makatulong. salamat po.
November 2nd, 2009 11:20 PM #2
I would think it's either a valvebody problem or the 3rd gear clutch packs are worn and it can't engage third while under load. (meaning, it actually has to push the car, rather than just spin the wheels).
THE AUTO SPECIALIST
- Mar 2006
- 607
November 3rd, 2009 12:29 AM #3computer controled ba yug tranny mo? kung computer controlled, kailangan diagnose muna using a compatible scanner before trying to replace things .
scan for codes and go from there.
- Nov 2009
- 2
November 4th, 2009 10:47 PM #4*niky - bro pinalitan na yung buong transmission ng dalawang beses, ganun pa rin ang problems
re scan codes, meron kami nun dito walang trouble code na nilalabas so we are facing a blank wall right now.
thanks sa mga advice pero may problem pa rin po. i'll appreciate any advice.
November 6th, 2009 02:06 PM #5
THE AUTO SPECIALIST
- Mar 2006
- 607
November 7th, 2009 08:37 AM #6good to know that you are equipped with scanner , try getting into the data and see what the computer is trying to do
November 7th, 2009 09:41 AM #7
eh di ba back job yan pag ganyan. nagpalit ako ng tranny sa Mazda ko 4x kasi hindi nila makuha kuha, there was a time na ayaw din pumasok sa 3rd gear and the problem was the electricals of the tranny, nevertheless, i made them replace the whole tranny until it was ok.
November 7th, 2009 04:55 PM #8
basti08,
had that experience before with 1990 toyota cressida, a pin on the metri pak conector behind the a/c control panel was bent and no continuity between the transmission control module to the transmission. had this too on chevy (gmc) syclone, again, a terminal was bent on the connector. there were a couple more experiences i had with north american cars and asian cars i worked with. it is not uncommon specially if you are not careful with the mulitple pin connectors.
jickLast edited by jick.cejoco; November 7th, 2009 at 05:30 PM.
Monk-owned R53
