Results 1 to 10 of 10
    Aug 2005
    went to honda casa today, inquire bout my a/t problem, solution nila is to overhaul daw ung tranny, here's there computation:
    A/T Gasket - 9,520
    ATF Strainer - 1,299
    Labor - 8,000
    what do u think guys, mahal ba? nagloloko kasi ung a/t ko, pag mainit na makina hindi na nagshi-shift ng gear.
    ganun talaga presyo usually, actually im surprised under 50K sya...
    Feb 2006
    Mura na yan for a job sa honda casa pa. Just had the a/t of my gen1 crv overhauled 3 weeks ago here in Baguio. Cost me P21K. Well, wala kase casa dito and the price of parts, medyo mas mahal ng konti kasi by order lang and auto supply's don't usually have these parts on stock:
    Rebuilding Kit - 11,500
    AT Filter - 1,900
    ATF - 1,100
    Gas - 450
    Labor - 6,000
    Inquired also for a surplus AT pero it costs too much:
    48K - cable type
    65K - electronic type
    What Honda dealership did you have your estimate? Before I had my overhaul, I also inquired thru phone sa mga Honda dealerships:
    Honda Pangasinan - 35K labor + 9,061 (Rebuilding Kit) + 3,525 (Filter) + ATF
    Honda Marikina - 45K for an AT swap. They do not overhaul AT's daw.
    Honda Kalookan - 30-40K labor only parts not included.
    Problem was barado na yung filter and may mga clutch disc na worn out ng konti. Nung una, it was running normal & no signs na for overhaul na pala. Until one day, bigla nalang na erratic ang shifting. Then next day, the a/t was dragging when you hit the accelerator hard, until every 100 meters ayaw na gumalaw as in parang naka neutral nalang. Have to turn off engine. Turn on and ok nanaman for 100 to 200 meters and so on. After the overhaul, so far ok naman for the past 3 weeks. Run mga 400kms city driving and ok pa naman. Will test drive on highway by weekend. Since bagong overhaul daw, have to change ATF after 1000 kms.
    OT: BTW, used AC Delo ATF - compatible with DexronIII & Mecron. Ok ba itong ATF na ito for honda AT's? Has anyone tried it?
    Aug 2005
    i went to honda pangasinan, since i'm from dagupan city. un pa pala ang di ko natanong, mga price ng clutch disc if ever worn out na rin ung sa kin. para san ung rebuilding kit?
    Feb 2006
    Quote Originally Posted by mikejohnny
    Rebuilding kit eh yung overhauling kit ng A/T. Kasama na dun lahat ng mga clutch disc, o-rings at gaskets. Ano pala ride mo?
    pomelo: sakit sa bulsa!
    honestly di ko alam kung ok lang yun ang ATF dahil kahit san ako pumunta may special grade na atf ang honda eh, i mean, kahit mga 3rd party manufacturers they make a special honda grade atf...
    Apr 2006
    Ot na rin lang:
    anong ATF fluid ang dapat kong bilhin para sa honda ko. gusto ko kasi mag-change ng fluid eh.
    Aug 2005
    Quote Originally Posted by pomelo
    civic 96 vti. kung tutuusin mura na din pala ung nacanvass ko, they assure me naman na babalik daw sa normal shifting ng gear. kung matawaran ko lang sana ng 50% labor nila medyo iiwan ko na car ko sa kanila for repair.
    i've read also in this forum more than 3 months ago na, na meron daw atf that cost 1k+ per liter, and it made there problem solved nung ginamit nila yun, do u know what atf brand is that and where can be bought?
    ok lang ba yun na after 10 years ngayon na kinailangan ng overhaul? is that the normal lifespan of an a/t tranny?
    Feb 2006
    No idea kung anong atf yun. Pero if you want to take the risk -- pag hindi gumana yung flush/refill with ATF, overhaul din ang bagsak nyan, so magiging doble gastos. But that's only me. It's all up to you. Hirap kase sa Honda, the ATF filter is not replaceable thru the normal servicing lang unlike other cars. Kailangan ibaba yung a/t para ma-inspect/mapalitan.
    Suggestion ko is have the a/t down. Pa inspect mo yung mga clutch discs baka pwede pa, baka kase yung filter/strainer lang kailangan palitan. At least makakamura ka ng mga 9K+. Try mo hanapin si Pedro (service manager)sa Honda Pangasinan kung siya pa rin ang nandun. Mabait yun. Good luck.
    Quote Originally Posted by theveed
    Sir theveed, sakit talaga sa bulsa. Buti nalang may credit card... hehehe..
    so far ok naman ang performance, do I need to have the atf replaced with the Honda Z1 ATF? Ok lang ba na mag halo yung atf since pag drain, hindi lahat ng atf lumalabas kase may naiiwan na mga 2liters sa torque converter? what do you think?
my a/t problem - OVERHAUL
