Results 1 to 10 of 10
    Aug 2005
    good day, i've posted already rerarding my a/t transmission overhaul problem.
    now i would like to gain some knowledge if it's possible if i'd just convert it to manual transmission and i could save more pesos than try overhauling the a/t ( by replacing with a re-manufactured tranny which is estimated 50k+ at casa).
    how much do u think will it costs me, and things that will need to be replace? mine is civic vti '96 A/T
    Aug 2005
    manual transmission 4 civic below 20T, stick shift assy with cable na 1.5-2.5T all surplus saka hanap ka ng center console box na pang civic manual. d lang natin alam pa e kung pwde iconvert or disable ung A/T sensor ng ECU
    Jun 2007
    Quote Originally Posted by joey View Post
    Hi Joey, how about conversion of manual to automatic transmission for a '97 Civic VTi? Possible ba ito? Mahal kaya? And will it require conversion of the ECU too?
    Aug 2005
    Quote Originally Posted by ooba99 View Post
    around or - 20T din ung matic sir, same din kay mkejohnny a/t shifter assy wd cable at center console ng vti matic ang kylangan mo. if ever d pwede disable or convert speed sensor swap/trade in ur ECU na pang matic ( swap kyo ni mikejohnny pati na rin center console at shifter kung magksundo kyo hehe) at ung wiring lang ng tranny sensor ang gagalawin lana iba
    teka u nid also radiator na may oilcooler or install kna lang surplus na oilcooler at linkage for a/t tranny cable s may throttle linkage ( dko lang matandaan kung cable type or electronic na ang vti)
    Nov 2003
    medyo pricey pero i'm pretty sure you'll fall below the 50k for the repair of the auto tranny.
    Aug 2005
    ok, so now i'm decided to convert it to manual and these are the things my friend told me to look and buy for conversion.
    1. Linkage
    2. Clutch Master
    3. Pedal
    4. M/Transmission
    5. Mechanic (Labor)
    anyone here who has an idea or at least just an estimate how much each part would cost and also the labor. It will be a very big help. And also kindly add kung me nakalimutan na dapat palitan.
    BTW, how bout pala ung ECU me kelangan ba i-adjust?
    thanks.
Matic to Manual convertion of civic 96
