Results 1 to 7 of 7
March 17th, 2009 06:37 PM #1
m/t fluid for the toyota corolla xe 1999 model with the 1.3 carb engine...
can't seem to find the recommended fluid type sa manual... unlike honda na naka specify yung spec (10w-30 engine oil).
should i just let the petron guys fill it with whatever gear oil they have or is there a recommended fluid for this thing? clutch is fine and still malambot, but in the morning i'm having trouble shoving it in reverse or 1st gear. i'm guessing tuyo na yung fluid reservoir nya sa transmission (this car receives next to no maintenance apart from oil changes once a year... at daily beater pa. i love toyota cars... massively reliable).
March 18th, 2009 05:49 AM #2
Transaxle gear oil
Oil grade API GL–4 or GL–5
Viscosity SAE 75W–90
Capacity 2.6 liters (2.7 US qts, 2.3 Imp. qts)
and if a 4 wheel drive Corolla:
Transaxle oil (M/T, differential and transfer):
Recommended oil Transaxle oil E50
(08885–80206) or equivalent
Oil grade API GL–5
Viscosity Above –181C (O°F) SAE
75W–90, 80W–90 or 90
Below –180C (O*F) SAE
75W–90 80W–90 or 80W
Capacity 5.0 liters
(5.3 US qts, 4.4 Imp. qts)
Anyway, you'll need to look in your owners manual or call a toyota dealer. These day's they switch what they use in manual trannys too much. Once you find out what it is then just use a good name brand, and if you want to drive the car forever then use a synthetic version(just an opinion).
March 18th, 2009 08:07 AM #3
- Sep 2007
- 215
March 18th, 2009 08:36 AM #4ndi naman kailangan na synthetic eh ...
try using mobil na gear oil GL-4 na siya and ndi sakit sa bulsa
price is around 180
- Feb 2008
- 577
March 18th, 2009 12:17 PM #5synthetic multigrade gear oils are expensive - even more expensive than engine oil.
since asa pinas naman tayo kahit monograde na gear oil pwede. just take note that if the manufacturer says gl4, use gl4 NOT gl5 unless its compatible with gl4.
monograde gear oil such as spirax g sae90 (gl4) costs iirc 1xx.xx+/L while rp max gear 75w90 costs 8xx.xx/L
March 18th, 2009 03:17 PM #6
hmm. what do they use * petron/shell repair bays? yung nasa malaking canister na de-hand pump? are those gl4 or gl5?
tignan ko nga mamya...
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 10th, 2009 10:45 AM #7you'll have to check the packaging to make sure it matches the requirements.
the castrol protector series is pretty decent na. it's an 80w90 gearoil that's gl-4 if i'm not mistaken.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
