Results 1 to 9 of 9
    Nov 2011
    newbie question lang po mga sir:
    possible to convert AT - Manual?
    my ride is an import - toyota lucida.
    how much will it cost?
    kung meron po kayong recomended shop please PM nyo po ako.
    (wala pa naman problema un AT ko but wanted to convert it to manual)
    thanks in advance.
  2. #2
    It's possible to convert an A/T vehicle to M/T, an uncle of mine had already performed some of those conversions. I'm not sure how would it cost because it depends on which transmission you're considering to adapt, but possibly the one out of a Liteace or a Hilux would be your best bet.
    syempre possible
    all you have to do is look for a manual tranny to mate to the engine
    hanap sa mga surplusan
    syempre possible
    Plus the clutch pedal and linkages.
    May 2009
    walang imposible!!!! hehe....
    bago mo iconvert, eto mga iconsider mo:
    1. trans support and mounts
    2. exhaust piping
    3. flywheel and ring gear
    4. starter compatibility
    5. alignment ng butas para sa shift lever
    6. driveshaft compatibility (spline, diameter, length). dalhin mo driveshaft mo para matest kung sasalpak sa nahanap mo na tranny.
    7. firewall area (kadalasan mas malaki auto tranny so wala siguro problem)
    hth
    Oct 2011
    How much is the cost on converting an AT to MT?
AT to Manual Transmission
