Results 1 to 11 of 11
    Apr 2015
    Hi po mga sir! Normal lng nmn po na nag vivibrate yung stick shift diba po? Lalo na kapag naka neutral klng habang naka on yung engine dba po? Kasi ngaun ko lng naramdaman pagka vibrate nya nung one time naipilit ko iprimera tapos may narinig akong bakal na tunog sa may transmission na parang pumitik. Medyo malakas pgkarinig ko kasi nka open windows ako. Big deal po ba yun? Looking forwars on your replies mga sir!
    Quote Originally Posted by jiesix View Post
    Anong kotse / ride nyo sir? In most conventional and mechanically linked shifters do tend to emit vibrations as they're almost completly linked to the engine. But with most cable linked shifters nowadays, wala o halos wala na yung vibrations. Things you might want to check: 1. Engine supports, 2. Transmission supports, 3. Engine condition, timing, idling, etc.
    Sep 2012
    If it wiggles left and right or naiaangat mo ng konti, pwede mo muna ipa check shift stick bushings sa ilalim nyan.
    Around 60 to 80 pesos a piece yun usually you will need 4 or more depende sa make and model ng ride mo.
    Jan 2009
    I just remembered when I used to drive our then company van, a Diesel Toyota Revo, the stick shift would bang your knee every time you start the car. You have to remember to keep some distance between your knee and the shifter prior to starting the engine or you'll limp for a day.
    Aug 2015
    Quote Originally Posted by jodski View Post
    sir, 2000 civic lxi po kotse ko, may shift stick bushings po ba to? thanks
    Sep 2012
    Quote Originally Posted by luffin View Post
    yung nagtanong ako sa auto supply ng pinalitan ko dati sa mazda ko, sabi sa akin universal yun.
    Ang difference lang is yung size ng butas and yung kapal. It looks like a washer na makunat na rubber.
    Malalaman mo lang kung ano type kailangan mo once nasilip via lifter yung ilalim ng area ng shift stick and na inspect yung connecting joints under it.
    Once napalitan yan maaayos din pati yung play ng pag shift mo
    Sep 2012
    Google nyo na lang ang keyword na "shifter bushings" and then go to images.
    Aug 2015
    sir kaya po ba ng mechanic sa mga gas station ung pagpalit ng shifter bushings? usually po magkano labor nito? ty
    Sep 2012
    With regards kung kaya sa gasoline station sir, depende na yun sa available mechanic nila.
    Just make sure na may lifter yung pupuntahan mo kasi may dudukutin sa ilalim and para hindi ka abutin ng 1 hour pag pinalitan.
    Sa servitek nung pinagawa ko kasama pa na nagpaoalit din ako ng crossmember bushing charge nila sa akin 1,500 and that was around 2 years ago
    Aug 2015
    mejo mahal pala labor.. salamat sir!
Manual stick shift vibration. (Newbie)
