Results 1 to 3 of 3
    Aug 2010
    I am having a problem on my Toyota Corolla Bigbody (2E engine) clutch...
    ang tigas ng kambyo ko, hirap kumambyo minsan, minsan may sabit..pero pag inaalis ko yung floor mat (para sumagad yung tapak/lubog ng clutch pedal) Ok, siya ikambyo..then kanina nung mag-checheck ako ng clutch fluid which is ok naman (nasa maximum level), clutch master cylinder and clutch slave cylinder...i checked the clutch slave then pinush ko yung clutch fork tumutulak naman siya....then nung pinaandar ko, ayun na..wala ng resistance yung clutch pedal pero natulak parin daw yung clutch fork pero konti lang daw sabi nung assistant na pinatingin ko, as in di ko na talaga siya mai-kambyo. ano kaya ang problema nito? repair kit lang kaya ito ng clutch cylinder/clutch slave or the worst clutch disc or pressure plate na? sana mapaliwanagan niyo ako dito. salamat.
    Quote Originally Posted by zap.FREEDOM View Post
    Check mo slave if may tagas kapag inaapakan habang nakaandar. Check mo din clutch cable.
    For clutch disk, pressure plate and releasing bearing, kelan ba huling palit niyo?
    Apr 2010
    ^Afaik walang clutch cable ang bigbody corolla. Hydraulic type clutch. Malamang repair kit lang yan sir. Seiken brand. Palitan nyo na yung master at slave cylinder. Siguro mga 600php lahat.
    Peace out!
M/T Problem: Clutch goes to floor without resistance
