Results 1 to 8 of 8
- Jan 2009
- 16
February 11th, 2009 06:56 PM #1Hi, This started nung nagsudden stop ako nung isang araw (a s***** bus driver suddenly stops para magsakay ng pasahero) since then napansin ko na bigla na lang mahirap mag 1st and 2nd gear, medyo naging rigid. talagang hirap and matigas. ano kya nangyari? my car is a manual lancer GLX'05.
February 12th, 2009 06:53 AM #2
I can suggest two main probable causes:
1. Worn-out synchros
2. Clutch issue:
a. The clutch is not being pressed down deep enough
b. If it's cable type, it may need some adjustment
c. If it's hydraulic, check for any leaks, the fluid level, and if there's a necessity to bleed the system. It could also mean that either the master cylinder or slave are blowing fluid past the pistons
To confirm item 2c, try to pump the clutch a few times and see if that will get you into 1st gear much easier.
February 12th, 2009 10:47 AM #3
sir baka masyadong mababa ang timplada ng clutch pedal mo kaya walang bwelo pag umapak ka sa clutch? pag ba malamig ang engine mahirap pa din ba i-gear change?
- Jan 2009
- 16
February 16th, 2009 11:53 AM #4To aga: mahirap din eh. Actually the intire driving is ganun siya kahirap. tapos minsan kala mo naka-engage na hindi pala kumagat, then merong tutunog na grrrr..... sa shifter.
To oj88: ok naman yung tapak ko sa clutch pag-change gear. kahit naka park yung car, diba dapat malambot? sakin nde eh. I think i'll be looking at 2b.
February 16th, 2009 02:52 PM #5
sir bigla bigla bang nagka ganyan or may pinagawa kayo last time na may kinalikot sa clutch pedal nyo? o kaya sir baka busted na nga ang shifter cable nyo karamihan kasi ganyan ang nagiging sakit like my mb100 hasle din yan sir mura lang naman ang cable,sana man lang kung low gear ang oto pwde ipasok sa 2nd gear
- Jan 2009
- 16
February 16th, 2009 05:43 PM #6to aga_cruz: Yung sudden stop lang yung naalala ko eh. ala pang ginalaw sa clutch. inattempt ko kc i-shift sa first gear kaso ayaw kumagat kya ng-neutral na lang ako. mukhang ngkaproblem dun sa shifting on sudden stop. Balitaan ko kayo pag nadala ko na sa shop within the week.
February 16th, 2009 06:04 PM #7
- Jan 2009
- 16
February 17th, 2009 12:04 PM #8Hi, how much kaya pa-repair/replace ng worn-out synchros o kaya ng clutch cable?
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
