there is nothing worng with your transmission. the clutch is for synchronizing the gears of your tranny when shifting. the gears can always be disengaged even without stepping on the clutch. kaya lang di mo ma-shift sa neutral in other gears e kasi sa 1st and 2nd mataas ang torque sa engine side so more effort to disengage an engaged gear. sa 5th naman overdrive yun, mataas naman ang torque sa drive shaft side.
ang masama e kung na-disengage siya ng di mo naman ginagalaw ang kambyo, because that means worn out na ang synchronizer gear.
