Results 1 to 7 of 7
    Sep 2005
    A week after I had my clutch repaired, napansin ko na may konting tagas sa transmission so I had the oil seal replaced. After several days, meron na naman. Di naman malaki ang leak pero definitely talagang meron. My questions:
    1)Ano kaya ang posible cause na nag leak uli?
    2)Kung very minimal lang naman, how long will it take para maubos ang transmission oil and what will be the symptoms/effects on the car?
    I hope someone can address this. Thanks very much.
  2. #2
    2 oilseal ba napapalitan mo? baka di maganda ang pagkakasalpak..
    pero alam mo, most oil seals/rubber gaskets in the market talagang pangit na...yan ang prob namin dito..
    Sep 2005
    Quote Originally Posted by alwayz_yummy View Post
    Actually sir, isa lang so I might as well have it checked again. Thanks.
    Nov 2003
    could be replacement oil seals or that they were not installed correctly.
    Quote Originally Posted by evag View Post
    anong seal ba yung pinalitan? yung rear crank oil seal?
    Ganito, observe muna for a few days kung nagbabawas ng langis ang "engine", kung nagbabawas ang problema siguro dun sa rear crank seal.
    Kung hindi nagbabawas yung "engine oil" it might be your gear oil leaking. There's another seal sa may tranny (can't remember the part, tripod something) baka kailangan na din palitan.
    Aug 2005
    pa underwash ka tapos after 3 days tignan mo ulit. if may tulo pa din oil seal na yan.. dapat orig japan oil seals para mahaba ang buhay ng seal.. pag down transmission sabihin mo palitan lahat ng seals para isang service charge lng yan and no worries .
    Evag,
    Saan mo nakita yung leak?
    Alin oil seal ang pinalitan sa may input shaft ba ng transmission or yung main crankcase oilseal? Inalis ba yung flywheel?
transmission oil leak
