Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
    Aug 2004
    #21
    Performance clutches really are expensive. You can expect to pay anywhere between 17 - 25k for a "Stage I" clutch. One that'll hold maybe 50% more torque (or a bit more) than the stock clutch.
    It still won't be indestructible... but it'll last much longer. Kaya lang, even the mildest "performance" clutch will be stiffer at the pedal than a stock clutch. If you're doing this just for longevity on a daily driver... forget it. Sakit ng tuhod lang aabutin mo.
    If you have no mods, just drive more gently, don't ride the clutch (drive the car at part-clutch) and practice smooth and quick clutch engagement (don't hold it at part clutch for a long time waiting for first gear to catch up... learn how to engage it quickly but smoothly).
    Dec 2007
    #22
    Drag racers with tuned Honda B-series engines I've talked to will actually tell you to forget ACT or Exedy clutches if your drag car is also a daily driver.
    If you've got a B16A/B or a B20VTEC hybrid/"Frankenstein" motor, you can just get a B20B/Z clutch disc instead from the casa. This is the clutch used on the very first CR-Vs. Way cheaper than the race clutches, yet still strong enough to withstand the kind of abuse drag racing will subject the clutch to.
    Aug 2004
    #23
    Quote Originally Posted by Type 100 View Post
    I'm still looking for an equivalent for the Lynx. The ACT I've got is stiff, but actually bearable, but something along the lines of the Focus TDCi clutch would be nice. I'm still trying to find out if the diesel Familia/Lynx used the same type of gearbox or at least a similar bellhousing to the gasoline-powered ones...
    Nov 2003
    #24
    the performance clutches wear out faster than the oem ones because of the increased clamp load and the friction material used sa disc. if you want longevity go oem.
    #25
    mga tsikoteers san po ba murang bumili ng clutch assembly? ride is a hilander slx 2000. maraming salamat
    #26
    saan po murang OEM clutch assembly ng hilader slx 2000.tnx bro
    Nov 2003
    #27
    exedy racing clutches are just under 20k fitted. mas matibay than stock from a racing point of view but they won't necessarily last longer.
    #28
    Our longest traveled vehicle had it serviced and replaced for the 1st time at 130T kilometers.
    Nov 2007
    #29
    im nearing 130thou km. manipis na clutch ko
    mga magkano kaya gagastusin
    nissan lec 94
    #30
    Quote Originally Posted by carlogt View Post
    try going to servitek. they have lots of parts there available. in fact, yung clutch nung friend ko na naka vectra, dyan din nakakuha ng parts eh.
    Nov 2003
    #31
    prices will vary depending on tranny and car model. it's best to call up your mechanic to ask the price for your specific car.
    Dec 2010
    #32
    My corolla xe 96 has a 230k km and still the clutch is working.
life span ng clutch system(disk,plate,release bearing,oil seal)
