Results 1 to 7 of 7
- Feb 2009
- 41
February 26th, 2009 12:45 AM #1hello...im kinda new here and its my 1st time owning a car in this counrty so i wouldnt know how much things run around here. i have a tranny leak and the leak is near the right axle boot. also...i think my axle boot is also leaking with all the gunk around it. can someone tell me how much things would run if i get it fixed? i hope no shops rip me off for a high price. thanks.
- Feb 2008
- 577
February 26th, 2009 05:55 AM #2is it oil or grease? if its grease, its probably your axle boot. this would need repacking and replacement of the boots if cracked.
if its oil, probably tranny oil. there is a seal on the diffrerential side of the tranny. this can be replaced as well.
you can bring it to speedyfix for checkup
- Feb 2009
- 41
February 26th, 2009 09:41 AM #3are they an honest shop? cause im thinkin it could just be my boot cause there is grease all over the bottom but then again i also found oil. how much would it cost around so i would know what to expect? thanks... oh and one more thing...is speedyfix an honest shop? thanks
February 26th, 2009 10:00 AM #4
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 10th, 2009 11:42 AM #5if it's just the boot then it shouldn't be too expensive. actually even if the seal is leaking it'll just add a couple of hundred pesos.
but it really does have to be checked first.
- Jan 2008
- 18
April 15th, 2009 04:52 PM #6Hello. Related question lang din po sa mga tsikoteers regarding leaking transmission fluid. My car is a 1999 toyota corolla (ae111).
Meron po kasi leak sa front middle part under the car. Tama po ba na 3 ang oil seals na kailangan ko ipacheck, 2 na axle oil seal and 1 rear main oil seal?
Kung yung sa rear main oil seal ang papalitan, may idea po ba kayo how much yun?
Thanks.
- Feb 2008
- 577
Traffic!
