Results 1 to 12 of 12
    Sep 2004
    Folks, the usual disclaimers apply. Kung may similar thread na, paki-direct na lang ako.
    I was driving last night when I heard a noise somewhere within the cabin. After some adjustments, I realized that the sound was coming from the gearbox. I tried to jiggle the shift lever while idling, and true enough, there was this jingling sound inside, parang may barya sa loob. Could there be something loose inside that needs to be tightened?
    I'm not encountering any difficulty in my shifts, although true to the vehicle's age and frequent use, I can sometimes shift from neutral without having to step on the clutch. Thanks in advance.
    Jan 2008
    tol try to check muna bka konti nlang gear oil ng transmission mu.. bka my leak sa ilalim di lng pansinin ksi di dapat maingay transmission,,
    remember nakababad sa gear oil un
    check your crossjoints. it could also make a "kalansing" sound when its going south. pag arangkada lang ba yun lumalabas?
    Not joking, have you tried removing the shifter cover (usually the rubber or leather cover around the shifting column)? I remember a friend of mine in college had that "clinking" problem around his gearbox console area and he brought it to a mechanic only to find out that he has quite a few coins and screws that slipped into those crevices.
    Nov 2003
    can you hear the noise from inside the car lang or pati pag nakabukas yung hood and you're looking at the engine?
    Sep 2004
    *darksword,
    Will check. According to my records, I had the gear oil changed at 60,000kms. My odo is now at almost 77,000kms.
    *afrasay
    Same thing, will have it checked first chance I get.
    *theveed
    Posible nga, although I'm certain that the shifter cover hasn't been compromised. Pabuklat ko na rin, since I carry a considerable number of coins on the dash.
    *speedyfix
    I hear the noise from inside the car. I tried driving with the windows down, and the sound is still coming from inside. Haven't tried opening the hood and listening to the engine, although the jangling sound disappears when I'm on idle. It's at its loudest when I shift to second gear.
    Jan 2008
    Quote Originally Posted by afrasay View Post
    Yes sir boogey bk po crossjoint... pag umarangkada cya...
    update na lng po pag bumalik
    sana po hindi intermittent at tlgng nwala n...
Kalansing sa transmission
