Results 1 to 11 of 11
    Hi All,
    Actually nag-search muna ako regarding jerking pero wala akong nakita same scenario ko so gawa nalang ako new thread.
    Ask ko lang kung what is the possible problem na na-experience ko kanina while driving home. Actually I drove from Manila to Boni para hatid gf ko. Ok na Ok takbo ko smooth na smooth. Kaso pagbalik ko after ko bumaba sa shaw overpass biglang nag-jerk yung sasakyan. Even if I was on 2nd or 3rd gear.
    Di ko sure if dahil ba sa timing ko ng pagtapak/release ko ng clutch/gas or nagkamali ako ng shift ng gear(pero alam ko kapag mali dapat tumunog sya ng malakas eh which did not happen).
    Nagtataka lang ako kasi nung huminto na ako nung nag-red yung ilaw sa stoplight nilagay ko sya neutral, release clucth and handbreak, then nung nag Green light na and nag 1st gear ako ok na yung takbo ulet hanggang bahay smooth na ulet even when i switch gear.
    Thanks po sa lahat ng sasagot. :-)
    when was your last tuneup?
    when did you last replace your fuel filter?
    water contamination in the gas?
    Was your fuel level low or was the car tilted to one side for any length of time before when it happened?
    Sep 2004
    Baka may nabangga ka or may natisod yung gulong mo na hindi mo namalayan?
    Seriously, am inclined to think na na-release mo agad yung clutch, while you were shifting, kaya may sudden jerk.
    Oct 2008
    sir naka open po ba yung a/c?
    Mga sir update ko lang kayo... tama ata si *Galactus ako may problem with regards to releasing clutch kasi I tried this morning ganun parin. 2 months palang kasi ako nagda-drive. Napansin ko tuwing bababa ako ng bridge and nag me-menor ako nangyayari yung jerking... Anu po ba ang proper way kapag pababa ng bridge? I mean dapat ba mag nuetral ako kapag pababa na then tsaka ako mag 1st gear? Manual transmission po yung car.
    *technismo - yes naka open yung AC
    *ghosthunter - marami naman fuel and not tilted for any long time.
    *Galactus - mukhang tama ka
    *1D4LV - binili ko sya last quarter of last year as 2nd hand. Could it be because nung nagpachange oil ako sa casa sabi sa akin papalitan ko na daw yung mga oil seals ko? (which is di ko pa nagagawa kasi kinapos sa budget)
    Thanks ho sa inyong lahat
    Oct 2008
    Quote Originally Posted by majorguile View Post
    sir baka sira na po yung pressureplate nyan..
    Oct 2008
    sir baka sira na po yung pressureplate nyan.. and sir try nyo po pag nakaoff naman yung a/c kung ganun pa din sir
    Oct 2008
    baka hindi match ang speed mo sa gear mo.
    Jan 2003
    Quote Originally Posted by a3n3as View Post
    I guess this is correct. IMO, since he's going down a bridge, the speed is relatively high, then the sudden change to low gear will cause engine braking, hence, the jerking.
Jerking problem Help
