Page 9 of 17 FirstFirst ... 5678910111213 ... LastLast
Results 161 to 180 of 327
    #161
    Same with our 1.3L iDSI CVT ride,- no need to reprogram the ECU after the battery change.... No problem whatsoever with our ride.
    Over a span of ~5 years,- replaced the battery thrice already. Last one was March this year... A battery, in our case, lasts for 18months approx.
    8800:juggle:
    Jan 2009
    #162
    Nakaka asar pag Honda CVT. Nalunod yung Honda CVT ko and I had to change CVT fluid 5 times before the fluid became clean and with no contamination. And it was over several days (as just changing like engine oil will not work). And one 3.5L cost P2K++.
    I might have done it incorrectly but then my CVT now is clean and not contaminated. Doing it by myself did save me labor charges (plus no waiting line).
    And I plan to change it again after 6 months just to make sure. Mahal pag masira CVT tranny.
    #163
    Guys,
    I bought a Honda Jazz 1.5 Vtec CVT 2007 model ung LED lights na last 2 months ago. I had a problem na namamatayan nalang bigla when stop and go ako.. then humina busina so i concluded that it was the battery so padeliver ako sa motolite. Then everything is fine na naman until after one month, parang bumababa idle ko.. same with suysuy pero 500rpm naman minimum ko.. then last thursday, namatayan then start automatically ako pag nagbrake nung nasa trafik ako sa c5.. pag trafik ko lang naexperience so i turn-off the aircon and radio para d mamatayan.. d nako maniniwalang battery na fault neto so i don't know what the problem is na.. dalin ko sa casa this tuesday palang.. ano kaya problems? 23k na tinakbo ng car... so iniisip ko baka CVT fluid.. try ko reatach battery later para mareset then test it again bka kasi d ko nareprogram ung CVT..
    Sep 2009
    #164
    good day guys,
    normal lang ba na iba yung tunog na maririnig sa cvt kapag naka reverse, kumpara pag naka d s and l mode.
    pareho lang kasi yung tunog ng transmission ko kapag nag shift ako sa d, s and l mode, pero pag shift ko sa reverse, iba yung engine sound. mas malakas ng konti.
    kotse ko pala honda city 2004 1.5 vtec
    maraming salamat.
    Mar 2007
    #165
    maybe its time that im gonna bring this issue back? please read
    http://tsikot.yehey.com/forums/showt...22#post1412822
    Mar 2007
    #166
    Jul 2006
    #167
    Hello all. My Honda City 1.3 idsi CVT 2006 never had a problem with the transmission. As a matter of fact, it is very reliable and very smooth. I just follow the fluid change as per manual (every 2 yrs or every 20T kilometer) . Its cheap, 2,500 every two years is a piece of cake.
    Mar 2007
    #168
    up lang. sino pa ba dito may problema? lets share some ideas
    Jun 2007
    #169
    ako po ung jazz ko po na cvt model 2007, casa maintained yung car, at talagang sinusunod ko ung sa checklist kung may mga kailangan replace.
    last january 2010 nag-uumpisa siya na tumatalon yung sa rpm (from 800-1300) kapag naka stop (for example: red stoplight) pero parang it had to happen once a day at tapos twice siya pipitik ung rpm, it went on until february dinala ko na sa honda to tell them kasi nakakainis na rin. ang ginawa nila calibrate and reset ng computer box, nawala naman ung pagtalon ng rpm, well for about 2weeks.
    Tapos ngayon ito na naman. i just hope it's nothing like sir suysuy's case. malapit na rin matapos ung warranty ng car ko. months na lang ang binibilang.
    Mar 2007
    #170
    tumatalon? wow. parang papunta yan sa case ko ah hehe. ok ba deceleration mo? sa akin kasi pag bitaw sa gas lets say from 60kph or 45kph, in just 3 seconds 20kph na lang takbo mo then it will just jerk parang rubber band na pumitik lol.
    Mar 2007
    #171
    buti nga 800 to 1300 lang yung jump ng rpm mo. sa akin paminsan 200rpm nalang ang idle ko hirap na hirap na ang makina. minsan naman 1500rpm. and worst case scenario? up and down up and down up and down.
    Jun 2007
    #172
    yung sa akin sir once a day lang nangyayari. parang may sumpong 2x pipitik yung rpm usually papunta ako sa office pag naka stop at naka tapak ako sa brake, tapos nakaset sa "D". pero pag umaandar na ako, hindi naman weird yung galaw ng rpm ko. pansin ko gumaganun lang cia from cold start going my usual driving style, hindi naman ako mabilis mag drive i see to it na nasa right temp ang makina before i get to drive the way I used to. isa pang napansin ko from stop, release ko brake then tapak na ko sa gas, parang may vibrating na feel to it yung para sa manual kapag kulang sa clutch ba yun. sorry kasi sobrang tagal ko na di nakahawak ng manual, last i remembered nasa driving school pa ko.
    pero pag pauwi na ako wala naman na akong napapansin na pagpitik ng rpm. I already talked to my dad na, he said to observe ko muna for a while. siya na bahala makipag usap sa honda after, i think the guys there sa honda is not taking me seriously parang wala sila alam kung ano nangyayari. dapat alam nila na may ganyang issue.
    Mar 2007
    #173
    yan ang tinatawag na judder. google honda cvt judder. youll be surprised with the results. your start clutch might be beginning to show its wear and tear. our cvt does not have a torque converter, but it has a clutch.
    wag mo nang patagalin yan. worst case scenario, hindi na tatakbo yang jazz mo hehe.
    can i have your cp number?paki message nalang sa akin. i wanna talk about this. i have a lot to ask hehe
    Feb 2006
    #174
    good luck sayo suy..
    i had similar problem with you but i didnt bother to repair it.. binenta ko na lang ng palugi and too bz to fix it..
    i rather spend time working that fixing hehe..
    marami talaga nag kaka prob sa CVT. i can say more than 75% ang A/T CVT
    but ther are some na nakukuha sa flushing it 3 times
    but i guess yung sayo wala na pag asa..
    to know more about you car
    check out www.jazzcityunited.org
    Mar 2007
    #175
    sold the car already
    Jul 2006
    #176
    Quote Originally Posted by rpga443 View Post
    I disagree with you sir. I know a lot of people having a car with CVT but they never had a problem like yours. My two officemates cars are honda cvt 2004 and 2003 but until now gamit nila pamasok arawaraw...80km/aday 5times a week. This is the reason din kaya bumili ako ng car with CVT din, mine is 2006 model CVT, never had a problem until now like what you described. Maybe some has problems due to factory or maintenance issues..but I strongly believe it is not >75%. May mga manual tranny kahit brand new nagkakaproblem din, i know some. Kaya from then, nagtiwala na ako sa matic at di naman ako binigo sa tagal ng paggamit ko sa car ko.
    #177
    Quote Originally Posted by suysuy View Post
    Oh wow,- it's just like losing a baby....
    So, I presume na hindi rin pinalitan ng Honda? ...
    9606:hippie:
    Mar 2007
    #178
    yep. i was kind of emotional at first. 4 years ko dinadala dala yan araw araw. sobrang daming places napuntahan at memories yang city na yan hehe. nagusap na kami ng dad ko about this and we agreed na surrender nalang hehe para wala nang sakit sa ulo. total, bibili nalang daw siya ng ibang sasakyan. napunta sa akin FD civic niya hehe. bye bye GD City
    #179
    From a City to a Civic,- I'd say it's a sweetheart deal, bro.....
    9606:hippie:
    Mar 2007
    #180
    yup yup haha! but still, there are some things that can really be missed hehe.
Honda Jazz/City CVT Problems. Anyone?
