its been 2 weeks since i encountered this weird thing with my V,ill try to be as accurate yung pag describe ko sa issue nya at sana matulungan nyo ko mga master on what to do
issue
ililipat ko nang parking si V pagstart ko like ussual na ginagawa ko painitin ko muna mga 5 mins then put it in R (reverse) ok naman sya mga 100 meters then when i put it on D (drive) kagat agad dahil magmamaneobra ako while in drive napansin ko pahina nang pahina yung hatak nya kaya ginawa ko i put in nuetral muna then r as is walang nangyari kahit naka D or R naka nuetral pa rin sya need ko off engine and turn on ulit gagana na sya thats the first symptom na nagloko si V
next day nagcheck ako less than 200 meters while in D nawawala talaga hatak need off engine ulit then on pero me time na pagoff ko at start ulit ayaw na kumagat sa drive or reverse
so I called my trusted mechanic and check my v kung ano nagiging sakit nya and tell me that we do atf flushing muna after flushing ganun pa rin so ang final verdict is tranny overhaul/rebuild,
no blinking d4,no checke engine light
so ayun nirebuild nila tranny all oil seals,gaskets and clutch disk has been replaced pati atf genuine honda nilagay dahil napakaselan daw ni V then test drive namin im from blumentritt near lrt station drive ko papunta north cemetry )in case magloko d ako magcause nang traffic :grin ) ok shifting binibirit ko but on our way home naghighrev na naman sya at kahit naka Drive (D4) ay nawalan na naman nang hatakso ang nangyari off ongine then on ok na ulit but me time na nagdrag si V at nawawala na hatak
that was around 5pm we let it cool ikot ok na naman but pag pauwi na kami nagkakaganun pa rin,ang sabi ni mechanic i check nya kinabukasan yung mga solenoid kung ok daw
the following day after office hour bumalik si mechanic and checked the soleniods ok naman daw ang reading ang ginawa inikot namin para uminit at nireading nya ulit ok naman daw at d nagloko si V dahil siguro d ganun kalayo ang narating namin
and this morning naglakas loob ako ihatid mga anak ko to school using V blumentritt to tayuman pritil ok naman sya d nagloko by the way ang takbo ko pinakasagad ay 60kph dahil naphobia nako biritin baka magloko na naman at itirik ako with my kids
mekaniko will be back this sunday ulit para ibaba aulit ang tranny baka daw meron mga seals na nasira
pagod nako kakaisip at malapit na sumuko pati bulsa ko para mapatino si V meron po ba kayo mapapayo na pwede ko sabihin ke mechanic ko para macheck nya?
by the way yung mechanic ko charged me 35k for reman tranny
malapit na po ako sumuko dito ke V sana po mapayuhan nyo ko nang mga pwedeng i check nyapa para mapatino
pagpasensyahan nyo na po sobrang haba i want to be as precise sa mga nangyayari ke V
maraming salamat po sa inyo in advance
