Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Feb 2007
    [IMG]http://www.worldofthird***.com/mytransmission.gif[/IMG]
    ayan mga sir... naka-red ung "P" kase nanjan ung stickshift.
    kahit san ko ilagay ung stickshift laging ganyan ung "D4"
    dko alam kung wiring lang mga ser e. kase pag fresh start ng kotse,
    wala pang blinking.. mag-i-start sya mag blink siguro after 2 minutes.
    ano kaya problema mga ser? does anyone here had already went through
    this kind of situation?
    thanks...
    Quote Originally Posted by coca-cola View Post
    thanks...
    Is there any problems with the tranny when you are driving or is it just the blinking light? If it's just the light then it could be just a wiring or sensor issue, have it checked through the vehicle OBD for any error codes.
    Dec 2003
    OT hmm gif link ng pic mo from 'worldofthird***.com' ah :gayfight:
    Feb 2007
    Quote Originally Posted by redorange View Post
    wala naman ser.. smooth naman ung driving ko.
    wala kase akong driver's manual ng accord kaya dko alam
    baka may meaning ung blinking.
    iniisip ko baka warning sya ng kung ano. hehe
    salamat ser.
    Feb 2007
    Quote Originally Posted by BlueBimmer View Post
    OT: hahaha yes I own worldofthird***.com. BUT im not gay hahaha
    thats for business purposes only. my job kase is web related..
    So ibang klaseng stick shift o stiff stick! Peace!
    Nov 2006
    nangyari dn sa accord ko yan...una nagblink lang D4 then after a while nasira na speedometer. lumakas ba sa gas after magblink? nde ko pa nga npapagawa. pero diagnosis ko sa speed sensor. btw ano ave fuel consumption mo? exi or vti?
    Feb 2007
    Quote Originally Posted by macho palito View Post
    8-9km/l ako ser.. hindi ko pa napapa tune up kase e. city driving un..
    so nagbi blink pa ung D4 mo? baka wiring lang.
    Sep 2004
    That situation is endemic to Honda AT's.
    Best way to check it is have a shop with an OBD-II reader to diagnose it.
    Mahina ba hatak? Check for loose connections. That was the case in my 97 Accord.
    Jun 2004
    This happened to me before, speed sensor was faulty, 4k sa Honda yung price.
    Feb 2007
    Quote Originally Posted by Galactus View Post
    ano ba ser ung OBD-II?
    hindi naman mahina hatak, oks lang.
    ano den meaning ng OEM?
    Sep 2004
    OEM stands for Original Equipment Manufacturer. Ibig sabihin, original ang pyesa.
    OBD naman is On-Board Diagnostics. To be sure of the exact cause of your transmission problem, kelangan ng OBD reader. Sa casa or kay Speedyfix meron nyan.
    Here are the tranny-related problems (OBD). Pag nalaman yung code, madali nang ayusin yan.
    OBD-II Codes P0700 - P0799
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    Back To Index
    have the tranny checked kasi pwedeng nagooverheat na ang tranny mo. sa manual ng accord meron nakalagay na ipatingin sa honda kung ganun. goodluck.
    Aug 2004
    Have you tried changing your ATF? Baka luma na masyado yung fluid mo kaya nagwawarning sya. Try nyo po muna ito pagawa, ito po ang pinakamurang pwede mong gawin muna.. malay mo swertehin ka...
    Pa-check mo dun sa Shell Customer Cradle sa tapat ng Perpetual (Times Village) maayos at mababait ang mekaniko dun...
    OT: Saan ka sa las pinas bro?
    Feb 2007
    Quote Originally Posted by viper2lt View Post
    Quote Originally Posted by hyperthread View Post
    so pag nagbi blink ung D4 meaning may problema talaga? or baka naman loose lang ung wirings? bakit kung may problema sa tranny, bat sa D4 yung warning sign? i mean pede naman sila maglagay ng isa pang stuff sa dashboard para sa warning sa tranny. sana wirings lang,
    pa check ko na den yung tranny ko sa shell perps and sama na den mga fluids to make sure.
    thanks sa list ser galactus. so pag pinagawa ko yan, kahit mga taga SHELL alam den ba yung mga codes na yan? universal code ba yung mga yun OR pang honda lang?
    OT: taga manuela ako.
    //coca-cola
    Nov 2003
    is your speedometer working? a busted one normally results in the blinking d light.
    Aug 2004
    I think speed sensor ang problem mo po.. tama sila.. take a look at the link below..
    A/T Blinking Light
    OT: Coca-cola taga Manuela din ako.. yung papasok sa RFC.
    Feb 2007
    Quote Originally Posted by speedyfix View Post
    ayus pa naman ung speedometer ser. wirings lang naman un dba ser? hindi makaka apekto sa engine or sa transmission?
    Feb 2007
    A/T Blinking Light
    nice link ser.. salamat. atleast alam ko na kung ano ung disturbing blink na yan. hehe. tanong ko sa shell perps kung may OBD machine sila para sa kanila ko na lang papa ayos. sa manuela 5 ako ser. sa may academy of jesus malapit sa city hall.
    Nov 2006
    exi or vti syo? sken kasi 4-5km/L lang e
HELP! Transmission Malfunction? Pic Inside...
