Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Mar 2013
    Mga boss, hingi po sana ako ng tulong /advice kung ano po yung dapat kong gawin. Less that 4 years old pa lang po yung toyota avanza ko, A/T, 31k pa lang mileage. Regular po ang check up sa casa. last check up was last July 2016. Then last week, Aug. 08, suddenly ayaw na gumana yung reverse. Dinala ko sa casa last wednesday, i had it towed para di lalong masira yung tranny.
    Nung binaba nila yung oil pan, may nakitang mga metal. ang sabi baka galing sa drum ng multiple gear saka may mga powdered metal na nakita din. ang suggestion ng casa is overhaul at maraming papalitan na parts or total replacement ng transmission, ang estimate will cost around 280k. muntik po ako himatayin sa presyo.
    sa ganong kabata pa po ng avanza, posible po ba na masira na agad yung tranny ng ganun? casa maintained naman. pwede po ba maghabol sa toyota pag ganun? lagpas na po kasi ako sa warranty na 36 months.
    patulong naman po saka kung san po ako dapat magpagawa. btw, pina-tow ko na po uli pabalik ng bahay, dahil hindi ko po talaga kaya yung estimate ng casa. baka may alam po kayo na gumagawa ng matic tranny in cavite, pa-advise naman po.
    Please help!!!
    Thanks in advance po.
    as you said, wala nang warranty...
    consider replacing the entire transmission. it will probably be cheaper and less hassle. let us wait for other tsikoteers who will recommend their favorite sources.
    Mar 2013
    Sir, maybe 280k is cheap for you, but for me it's a lot of money. kaya nga avanza lang auto ko kasi di ako mapera, tapos babayad sa repair ng 280k. kung siguro naka-fortuner ako, baka pa masabi ko na cheap yung 280k,..
    Sep 2009
    Quote Originally Posted by Zyvan2013 View Post
    I think ang sinasabi ni dr.d ay instead of having it repaired, baka mas makakamura ka kung palitan yung buong tranny. He didn't say 280k is cheap.
    Anyway, I hope na i-consider ng toyota na icover sa warranty. If not, I'm sure may ibang option like surplus tranny., etc. Good luck!
    Mar 2013
    Quote Originally Posted by i.am.aids View Post
    Sorry kung na misinterpret ko sir yung sinabi ni dr D,..late ko na na-realize na ang ibig sabihin nya nga is to go for a replacement of tranny but hindi yung sa tranny ng casa na worth 280k,..
    sensya na sir,..sana nga madaan pa sa warranty,..thanks
    no, sir. 280K is not cheap to me nor, i imagine, to many of the people here.
    that amount of money can already buy me a good replacement vehicle. food for thought, sir.
    good luck.
    Jun 2012
    Maybe you can contact toyota. Baka mapagbigyan ka. Too early talaga na masira ang transmission
    Feb 2009
    Most Toyota warranty coverage for drivetrain (engine/transmission) is five years or 50k miles whichever comes first. In your case, you have the service documentation in your favor. Write to Toyota motor phill or write to TMC Nagoya. Hopefully they refer you to the nearest competent service center
    Mar 2013
    Thanks sa reply sir. Sana nga I-extend nila yung warranty nung transmission. Dapat talaga 5 years yun. I will email Toyota this week (manila & Nagoya) and see kung anong pwedeng actions nila. sana mapansin nila yung complain ko,..
    salamat uli sir.
    Mar 2013
    Quote Originally Posted by dct View Post
    Thanks sa reply sir. Plan ko na nga po mag-call & email sa Toyota this week and see kung anong pwedeng actions nila. sana mapansin nila yung complain ko,..
    Bakit nga ba sobra aga ng breakdown ng tranny nyo bro? Baka never pinalitan ng casa iyong atf niya although pinapalabas lang na pinalitan nila. Saang casa kayo usually nagpapa-service pala?
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
    Mar 2013
    hindi pa nila talaga pinapalitan yung atf bro, puro inspect pa lang. kasi nga as per manual, 40k - inspect, tapos sa 80k pa yung replace. Toyota dasma kami nagpapa-service.
    Sep 2012
    Hindi ba nakalagay sa manual to replace the atf every 40,000 kms kapag heavy use?
    Periodic Maintenance Schedule | Toyota Indus
    Minsan bro may naliligaw din na statement yan na "or every X years whichever comes first"
    I hope ma cover ka pa ng extended warranty bro
    Sent from my Asus ZenFone 2 using Tapatalk
    Mar 2013
    Quote Originally Posted by jodski View Post
    Sana nga bro makuha pa sa warranty. regarding dun schedule ng palit ng atf, sa manual nya kasi nakalagay, Inspect/replace if necessary sa 40k or 2 years whichever comes first, then Replace sa 80k o 4 years whichever comes first. saka naka-depend din ako sa recommendation ng service advisor, pag sabi nilang palit, palit. kasi naka-program na rin yata sa system nila yun na kung ano yung mga dapat gawin sa specific pms. minsan kahit nakalagay sa manual na di pa sched magpalit, nire-recommend na nila na palitan, like yung spark plugs. nung last pms ko nung july, di naman nag-suggest ng palit ng atf yung advisor, so i presume na ok pa. kaya nagulat na lang ako nung bigla na lang ayaw na gumana nung reverse. saka slight use lang 'to bro, kaya nga 31k pa lang mileage nito.
    sana nga bro maawa pa sila at makuha pa sa warranty.
    thanks bro
    Sep 2012
    thanks bro
    Dun ka nakalimutan i remind ng service adviser mo bro. Dapat sana nung ika second year kahit hindi pa umabot sa mileage nagpalit na...
    Anyway hoping for the best for you nama file pa yan under extended warranty
    Mar 2013
    yun nga bro e, hanggang inspect lang ginawa nila transmission fluid, tapos hindi naman nag-recommend na palitan na,..
    thanks
    Ah ok. unusually premature pala talaga iyong failure ng tranny niyo bro. What gives kaya?
    Jul 2016
    Sir try mo outside casa. May ka kilala ako.naka rav4. Anlakas ng jerk ng at nya sabi sa casa palit tranny which cost 280k daw. Ni recommend ko outside casa. Yun pala spark plug lang sira. Parang anlayo ata tranny to spark plug hehe.
    Sent from my SM-J500G using Tsikot Forums mobile app
    Mar 2013
    parang napakalayo naman nung recommendation nila na palit tranny sa spark plug,..hehe.
    san kaya sya nagpa-ayos bro?,..naghahanap-hanap na nag ko ng mekaniko na marunong sa auto tranny somewhere in cavite area, para malapit lang ang towing,..
    a bit farther than the boundaries of cavite, there's d & r fast auto repair service who specializes in tranny woes. they're good at what they do and they bill reasonably plus they've now got their own flatbed truck so maybe towing won't be too much of a side expense. at hindi din hassle kausap iyong owner na si danny. i can vouch for him and his guys
    lots of luck bro
Help!!! Toyota Avanza 2012 A/T early breakdown of transmission, 31k mileage
