Results 1 to 13 of 13
    Guys do you experience hard shifting in the morning specifically during your first start-up of your vehicle? Ako kasi ang hirap i-shift sa first and 3rd gear eh. Parang may sumasabit. Is this related to the warming up of a vehicle? Kasi after a few kilometers, and kung completely warmed up na ang sasakyan ko, ok naman na.
    :confused: :confused: :confused:
    Jun 2004
    I've experienced something similar, but it is just when shifting our old telstar to reverse first time in the morning after starting it up and when getting it out of the garage. It's been like that for a long time already.
    yes, normally that's a sign of that you have to replace tranny/gear oils na.
    Artpogi,
    Last time we checked ok pa naman ang oils eh. Also, bakit kapag completely warmed up na ang auto, ok na ang shifting? Anyway, i'll have my mechanic take a second look at my gear oil.
    Thank
    sa akin naman baligtad. kung kelan umiinit na ang engine, dun naman sya mahirap ipasok sa gear. parang ngang may sumasabit.
    Nov 2004
    sakin din po hirap din ipasok, may sabit..sabi sakin ng mechanic ko, i-adjust nalang daw ung clutch...p-adjust ko muna post uli ko pag naging ok...
    kung di po makuha sa replacement ng gear oil and adjustment ng clutch, then most probably there is a problem in one or all of the clutch component or in the transmission itself.
    Try the cheapest solution first, which is the replacement of the gear oil, then clutch adjustment, then clutch bleed, then kung di pa din ma solve ang problem saka lang ipababa ang clutch to replace the pressure plate, clutch disc and release bearing.
    I'm going to have my clutch components replaced this weekend 'cause I too is having problems shifting and I'm pretty sure my gear oil is pretty new cause I've just replaced them a few months back.
    Now if replacing the clutch components doesn't solve the problem, then it's the tranny na siguro, a synchronizer maybe or a gear, which is really expensive. (knock on wood)
    HTH
    Oct 2003
    Hard to shift to 1st or reverse when the engine is hot?
    I think it is time to replace your clutch assembly. Its a sign that your clutch needs replacement of the(disc, plate, bearings) and probably clutch cable too.
    It is not enough to adjust your clutch. You can drive it for a few hundred kms but you might end up stranded in a dark and perilous place.
    Its a SIGN so better replace it.
    Apr 2005
    hi, i too am experiencing the same thing when engine hot hard to shift. im planning to change the clutch plate, disk and bearings but was just wondering would a japan replacement be ok? the original ones are kinda expensive. ok na po ba yun replacement for everyday use. what's a good brand ba to buy for a sentra 93 eccs?
    Quote Originally Posted by scope
    ok naman ang replacements, kung meron Daikin Pressure Plates and clutch disk para sa oto mo, I suggest you get Daikin.
    Jun 2004
    sir, before changing the transmission parts, kung hydraulic type, i suggest i-pa bleed nyo muna clutch nyo or palitan na po ninyo yung master and slave cylinder repair kit. pag luma na kasi yung mga parts na 'to,pag umiinit na, nag iiba ang texture ng mga rubber parts kaya nagkakaroon ng air leak. hence, hirap i kambyo. kung cable type naman, check nyo muna yung cable. ganun din nangyayari sa old cables pag umiinit. gumaganit, which contributes to hard shifting.
    Apr 2005
    ok tnx, i'll start canvassing i already saw some but they're branded "paraut" i'll try to look for daikin
    Apr 2005
    i got a cable clutch check ko rin sya nasagad ko na rin sa adjustment pero hard shifting na rin after 3 weeks. nakapag canvass na ko sa may pasay taft yun ASCO ba ok for replacement? yun kasi natanong ko sa advance automotive
Hard Shifting
