Quote Originally Posted by eatmylens View Post
We have the same problem bro, mine is an AE92 also but the "Small body". This has been happening lately lang, but the thing is ma-e-experience ko lang sya sa simula(pagbukas ng engine) as in ang hirap ipasok ng primera tapos kapag magrereverse na ako(Primera at Reverse lang ung napansin ko na mahirap i-kambyo), sumasayad sya (Yung bang para kang nag-kambyo ng di nakatapak sa clutch pedal) pero kapag running na or nainitan na ung makina okay na sya, smooth na ung transmission. I had it checked and nalaman ko butas na pala ung secondary/slave cylinder and wala na halos laman ung clutch fluid reservoir. so I had it repair and filled it up with fluid, mas smooth na ung transmission even on running pero nung na-garahe ko na after an hour at aayusin ko na ung parking nya, sumasabit nanaman ulit ung "Reverse" tho, baka kanina lang and will check ulit bukas.
Check mo ung mga Cyclinders(Master/Slave) baka butas lang.
Update ko lang 'tong post ko. Di na sya mahirap i-shift kahit unang bukas lang. so, the aforementioned solution solved my problem
