bro ask lang ako kung anong ok na oil for my tranny?
transaxle po siya, with aftermarket 2 way lsd. bale napalitan na po ung stock differential nya ng aftermarket. ano po bang hiyang na oil para dito?
if it is a transaxle, make dead sure it will not be damaged by lsd oil. if it does not specify lsd oil, do not use it. this oil is mainly designed for rear differentials. using this on the transaxle might ruin your whole trans. just make sure it is what is prescribed by the car manufacturer otherwise, use the regular synchromesh gear oil
