Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Dec 2007
    when should we change the transmission oil of our car. mine is lancer 97 GL.
    I do it every 40k kilometers
    Magpapalit na din ako ng transmission fluid sa next change oil ko. Ang napupusuan ko ay Royal purple.
    ako yearly. mura lang naman e.
    Nov 2003
    recommended intervals are between 20-40k kms. the sooner the better though.
    Aug 2008
    pano po kung napalitan na ung mga kailangan palitan sa clutch pero mabagal pa rin pag paakyat ung kotse, ano pa po ang pedeng cause nito?
    thanks!
    Nov 2003
    ano yung mga napalitan? sino nagsabi na kelangan palitan?
    baka naman wala sa transmission yung problem and it's with the engine na.
    Sep 2006
    Time to change Automatic Transmission Fluid in my Mitsubishi car with Tiptronic (+/-) semi automatic transmission and 90T kms mileage.
    The sticker in the hood recommends Diamond SP II ATF. Cant find any store with Dia SP II ATF, not even on mitsubishi exclusive parts stores.
    Some says a Dexron III ATF will do, but i dont want to mess up an expensive tranny by putting a wrong ATF.
    Does anyone knows a suitable replacement or have similar ATF specs but used different ATF brands with positive results.
    Your advise is anticipated with thanks.
    Nov 2003
    royal purple max atf multi spec meets mitsubishi SPII and SPIII requirements.
    Oct 2008
    Quote Originally Posted by speedyfix View Post
    sir, malapit lang pala office ko sa inyo, magkano pa-drain and replace atf? 97 galant ss po ang car. salamat po.
    Nov 2003
    rp atf is 700/lit, you will need between 3-4 for the drain/refill, plus labor.
    Aug 2008
    Every changeoil lalo na pag luma na ang kotche
    Oct 2008
    yup tama every 40k kilometers..
    Aug 2004
    sir, magkano ba replace ng transmission oil for toyota altis using RP? medyo matigas na kasi yung clutch ng altis ko. just finished my 35K PMS last saturday sa casa (under warranty pa kasi).
    pag matigas na ba yung clutch ano possible na sira dun? suggest kasi ng casa sa akin ibaba raw yung transmission to check ano problem ng transmission ko. hay, hindi ko na pinansin suggestion nila.
    thanks.
    ^^imho, pag matigas ang clutch, sa hydraulics yan... either sa master or secondary clutch. when was the last time you changed/drained your clutch fluid?
    Aug 2004
    Quote Originally Posted by 1D4LV View Post
    wala pa, sir kasi nasa 35K pala yung takbo ng altis namin. planning to change the fluids pa pagdating ng 40k.
    Nov 2003
    rp gear oil is 800/quart. it won't make the pedal any softer but it may make shifting easier.
    pag matigas yung clutch pedal that normally means kelangan na ibaba yung tranny to check the pressure plate assuming there are no leaks sa clutch master/slave.
    Aug 2004
    ilang quart ba ang kailangan for toyota altis if palit lahat? this will be the first time na magpapalit ng oil yung altis namin (nasa 35k palang yung odo).
    possible ba na may sira na yung tranny even if nasa 35k palang yung takbo? assuming normal driving habit yung paggamit ng sasakyan?
    what other transmission oil would you recommend for toyota altis (2007 model)? yung affordable price na sulit.
    Nov 2003
    you need about 3 quarts.
    pwede sya masira depending on how you use it. kahit normal driving lang but babad sa clutch pwede mangyari.
    Aug 2004
    thanks, sir sa reply.
    sent you PM.
transmission oil
