Results 1 to 12 of 12
    Feb 2014
    Quote Originally Posted by 1D4LV View Post
    clean throttle body.
    replace spark plugs
    replace air filter
    start ka muna dyan.
    pero imho, at 140 kph top speed, ok na yan. san mo ba susubukan in greater than 140 kph?
    air filter nalng po di ko napapalitan.. medyo nabibitin lng po kasi ako minsan sa rektahan/overtaking.. tinanong ko lng po bka sakaling may major problem or something sa kotse.
    Quote Originally Posted by ronskiee View Post
    hehehehe. di ka naman oovertake ng more than 140 kph bro.
    since AT yung oto mo, baka limitations yan ng sasakyan (via torque converter) kung more than 140 kph na. ang alam ko din sa AT kung overtaking, nasa driving style yan eh, dapat mag downshift ka via harder accelerator depress.
    have you also changed yung AT fluid mo?
    Feb 2014
    hindi pa po ako nagpalit ng ATF, sabi kasi ng ilang mekaniko tumingin ng ATF ko e ok pa naman daw. wala din po akong background kung kelan huling nagpalit ng ATF (kakahawak ko lng po kasi ng oto ^_^).
    imho, papalitan mo pa din to be sure.
    and again, imho, baka naninibago ka lang sa rangkada ng sasakyan.
    no offense sa naka city na AT with more likely same age or newer pa parang pgm-fi ata makina nun if i recall it correctly, na drive ko yung AT ng prof ko years ago when we have our class activity at taytay rizal with the town mayor. parang she is the PR for that particular mayor, di ko alng maalala.
    medyo bitin nga siya sa arangkada at parang hirap na hirap ang makina considering nakafloor na ako.
    Jan 2009
    Also include cylinder compression testing to your to-do list. It may simply be due to wear & tear or age (17 y/o). What is the current odometer reading?
    Jul 2003
    you expect the city to fly? kahit na honda may maximum rating.
Engine Hirap Umarangkada - Top Speed 140kph
