Results 1 to 10 of 10
- Nov 2002
- 25
July 30th, 2003 12:05 PM #1mga sir,
question lang po, ano po kaya ang cause, ng ayaw pumasok ng kambyo? o hirap? minsan nakaka 2 to 3 tapak ako sa clutch bago pumasok? usually sa 1st ,2nd and reverse gear lang po nangyayari..
btw, my ride is a 94 glxi lancer..thank you
July 30th, 2003 12:10 PM #2
maybe you need to replace your clutch system.
or worst that could be a synchronizer problem.
Try first to have your transmission fluid replaced sa iyong suking gas station. Observe for a few days kung ganun pa din.
Kung ganun pa din even after a tranny fluid change, have your clutch system and your tranny checked.
July 30th, 2003 01:58 PM #3
synchronizer key and synchronizer gear sa 1st/2nd gear train.
sa reverse baka adjustment ng linkage kasi mahaba ang throw nyan.
- Nov 2002
- 25
July 31st, 2003 09:31 AM #5maraming salamat sir sa mga replies...mukhang sa clutch master ang problema...
- Jan 1970
- 47
July 31st, 2003 05:01 PM #7Pahabol lang mga sir.... when do we have to change the transmission oil??? every 5,000km po ba or every 3,000km????
At anong magandang transmission oil na bagay sa 95 Toyota Corolla???
Salamat po....
BANNED BANNED BANNED
- 3,790
July 31st, 2003 10:04 PM #9jolam,
its usually aroung the 20-40K mark, kung me manual ka pa check it...iba-iba recomendation depending on car brand....pati na rin ang rate of use (abuse)...pedeng mas shorter and period ng change
August 1st, 2003 12:27 AM #10Originally posted by wildthing
jolam,
Kung bago na ang throttle body at servo motor, ang next suggestion i check sa YT search ay. 1....
LANCER Itlog (93-96) Owners - Please Post Here!
