Lube filter din ang B173S, with 20 psid bpv pressure setting. Alam ko, mas low viscosity ang atf than motor oil, so it can pass through easily sa filter media at ang filter head na gamit ko ay fuel filter head with pump kaya once na dumaan sa orifice with one way flapper, nowhere to go ang atf but to the sump, alam ko, zero ang pressure doon. Using this for more than three months na, so far, nothing unusual ako feel sa tranny, maganda pa nga performance ngayon. Kung may back pressure, magkaroon ng leaks sa mga clamped hose, wala naman, malinis at dry lahat, wala din enlargement ang hose from the cooler to the filter.
Sa looks ng atf, tested using white napkin, absorbed kaagad ng napkin ang atf from the dipstick, without residues left, very clean, no particles that can be seen, the color is the same as when it was first poured in.
Anyway, that also comes into my mind, to use hydraulic filter for atf, still looking for it, wala stocks sa mga suking dealers. Yun sana BT223, 3/4" - 16 thread, magpapalit naman ako ng filter head na mas mahal, M20 x 1.5 thread kasi ito nahingi ko filter head ng maisipan ko DIY ito.
Posted via Tsikot Mobile App
