Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    mga bossing. i had a problem sa starex 99 A/T ko. bagong engine overhaul po sya. newly change din tranny atf at gear oil. delayed po yung pag shift nya.1-2-3-4 gear.yung 1 to 2nd umaabot ng around 2000 rpm bago mag shift, yung 3rd mga 2,300rpm, yung 4th gear naman mga 2,700rpm sometimes abot pa ng 3,000rpm bago mag shift. naaawa ako sa engine , galit na galit bago mag shift. ano po kaya possible na sira o dapat icheck.?salamat
    Nov 2007
    pero tingin ko normal lang yun??
    at least may bwelo na diba??
    Nov 2007
    habol ko lang po bossing baka naka press button yung over drive mo sa shift knob or anything kung san naka lagay sa starex mo?
    kasi yung sa pregio namin dati ganyan din e yun pala laging nka eco power drive sya kaya lagi ag oover drive ang transmission
    Aug 2005
    Sa mga A/T na mga sasakyan, ang shifting point ay nagbabago depende kung gaano kalalim ang apak sa gas. So kung agressive ang tapak mo, possible na sa 3,000 RPM or more bago mag shift up.
    Dec 2007
    Oo nga, baka masyado kang naiinip sa pag-shift kaya medyo napanggigigilan ang accelerator, tuloy pataas nang pataas ang shifting point.
    Jan 2008
    Quote Originally Posted by jiyumaico View Post
    have minor adjustment to the Automatic Transmission Throttle Cable (can be seen on the engine throttle)... normally this cable is adjusted to the lowest setting but if there are delays in shifting..or slight slippage you need to adjust this to compensate.. on normal road and running condition A/T should shift just before reaching 2000rpm, if you step on the gas for more power shifting will be delayed slightly by past 2000rpm or more... adjusting your A/T Throttle Cable will compensate this delay in shifting
    Thanks guys sa mga inputs nyo. naka unpress po yung OD ng starex when i drive.smooth driving lang po ginagawa ko, sometimes yung 2nd & 3rd gear before mag 2,000 nagshishift na po, pero most of the time lagpas talaga sa 2thou. dati naman po syang smooth shifting lang, i mean hindi galit yung makina bago mag shift. 3 months ko kasi syang hindi nai drive since nagkaron ako ng driver that time hanggang sa nasira na at umabot na sa overhauling ng engine. so tinanggal ko na driver ko, after ma overhaul, eto na nga, pakiramdam ko delayed na yung shifting. kaya last monday nadaanan ko mitsubishi casa, dun ako nagpa change atf at gear oil, hoping magiimprove yung shifting pero ganun pa din.
    thanks din sir yapoy for the info, will try to ask sa malapit na mechanic sa amin about that cable. sana adjustment nga lang.
    bukod po sa Throttle Cable, may iba pa po ba akong dapat icheck? thanks
    Nov 2003
    that's the problem. if the overdrive button is not engaged (meaning overdrive off) then talagang mas mataas rpm bago magshift. try turning the overdrive on para bumaba sya.
    thanks sa reply speedyfix. is it you miggs? i bought RP dyan sa shop mo, gumanda fuel consumption ng focus ko.
    sorry na confuse din ako sa post ko.. i meant naka OD on parati ako mag drive. may possibility ba na synchronisers ang may sira kahit na delayed shifting lang? thanks
    Dec 2007
    Sir, try mo rin pa-check ang injection pump/system.
    will take note of that. thanks po sir woohoo.
    try injection pump indeed.
    the tranny does not engage to higher gear when it thinks you are on extra load. peru it was a power lost pala, not the load. after your overhaul, your engine might have lost some power. or the mechanic touched the pump.
    but if you can't find the problem in the pump or the engine, then you have to calibrate your tranny kick-down cable to the new overhaul power. meaning, you have to slack the tranny cable until getting the best result. don't loosen it too much though, it will burn your tranny faster.
    btw, you have to have it fix asap. prolonging it will permanently damage your tranny. the slippage might become permanent.
    Nov 2006
    hi! pareho tayo ng problema. musta na po car nyo? ano po pinagawa? ganyan na ganyan din sakin, pinapalitan ko narin ng atf kaso ganun parin. ok naman shifting nya minsan, minsan naman hirap na hirap yung engine kasi ang tagal talaga mag-shift, minsan unang tapak ko palang kahit magaan naman tapak ko umaabot ng 3000 ng walang shift-shift kaya minsan nilalaro ko nalang para para syang nagshi-shift.
    sana post po kayo kung kamusta na car nyo at kung ano pinalitan ha? sana yung throttle lang din yung sakin kasi masydo mabigat sa bulsa yung palit tranny na agad, wala na kong pera talaga. hirap lang ng walang sasakyan kasi hirap na lola ko bumyahe.
    Thanks sa advise sir rion.
    viepink; will post soon. wala pa lang akong time bumalik sa mechanic. asap palang maayos kaagad ito. will take sir rion's advise, dalhin ko na this tuesday para macheck na.
    update ko lang. just went sa malapit na mechanic, wala namang pinalitan, inadjust lang yung TPS (throttle position sensor at yung throttle cable). medyo um ok naman yung pag shift sa 2nd gear (mga 1,800 to 2,000) nag shift na kagad, pero yung 3rd at 4th ganun pa rin, mataas pa rin rpm bago mag shift. im not satisfied pa kaya if may time uli ako, dadalhin ko na sa casa.
    Nov 2003
    jiyumaico, yup it's me hehe! no problem... goodluck sa problem
    Thanks speedyfix. sori medyo OT. do you do spacing sa shop?balak ko palagyan spacer yung wheels ng focus ko. have you done it na ba sa focus?what are the pros and cons of putting spacers?if you do i'll drop by one of these days sa shop nyo. thanks
    Nov 2003
    sorry we don't. just go to any wheel shop and normally they sell generic spacers there for the corresponding amount you want to space the rim. normally they come in 5mm increments.
    Nov 2007
    hi sirs...ako din may prob sa at. pag first start kasi, mejo delayed mag kick ang transmission, especially ung reverse. Is this normal? its an old car na din, a 96 corolla gli matic. also, is it still normal for may speedometer to reach around 2800-3000 RPM at 80km/hr
    thanks a lot... so much to learn information from the posters here
    Jan 2008
    not normal po yan situation ni cliffy1523, dapat when you engage to R dapat engage agad yan no delays.. at normal driving speeds and acceleration. 60km/h nasa 2000rpm to 2,200rpm lang dapat ang engine rpm and your transmission is already at 4th gear just before reaching 80km/h you will feel another "kick in" of the transmission (actually this is the additional GRIP provided by the torque converter as its ATF pressure is increased) and your rpm will drop to 1,800 rpm to 2000 rpm and from this you will reach 100km/h at 2,500 rpm more or less..
delayed shifting
