When my gear is on 2nd or 3rd, 4th I think even on 5th my gear shaft makes this weird sound when I hit the gas pedal. I think the vibration causes it and its as if some screw is loose (this is while not holding it and letting it rest) but if I hold the gear shaft and move it a tiny winy bit back to the center just so that it isn't leaning the sound is gone (The car is still in the right gear). How can I fix this loose gear shaft problem? Thank you
