Results 1 to 3 of 3
    matagal ko na naoobserbahan ito pero I just ignored it dahil wala naman apparent effect sa takbo ko...
    Everytime kasi na i-engage ko reverse gear, just before reversing, I always hear this noise na "CLANK!", usually after I let go of the clutch... bale ganito yung sequence: apak clutch, engage reverse gear, gas ng konti, then release clutch, then "CLANK", yun na, pero nakaka reverse naman ako smoothly and when I disengage the reverse gear, bihira or di mo na maririnig yung "CLANKing" noise.
    Normal ba yan? o maluwag yung clutch/clutch plate? what do you think is wrong?
    Kailan ba ang clank? Baka yung backlash ng rear diff mo iyon. You don't really drive in reverse the whole day so you can just ignore it.
    Kung sa tranny naman iyan, it can probably wait until your next transmission pulldown (e.g. when time comes for a new clutch).
    Iba naman ang nagyayari sa akin: apak clutch, engage reverse gear, then "CLANK". But I think it's normal dahil walng synchro mesh ang reverse gear.
    Check mo na lang propeller shaft mo baka may play na. It can also be caused by the differential or the tranny. Hindi siguro bago pa ride mo.
Clutch Noise when reversing
